Intake Manifold Swap
Old 05-12-2003, 12:24 AM   #1
Rep Power: 14 MR.B is off the scale
Total NewBIE here!!!!!
Can you swap intakes manifold on a GSR motor....
I heard that the dual intake is a little restrictive when it comes to an all motor applaction...
Someone said a type r or b16 intake manny won't bolt up....
Is this true????
I trying to stay OEM with my parts!!!!!
I don't want the skunk intake manifold...
<a href=\'http://www.glock.com/enterprise_logo.jpg\' target=\'_blank\'>http://www.glock.com/enterprise_logo.jpg</a>
In Glock I Trust!!!!
MR.B is offline   Reply With Quote
Old 05-12-2003, 12:33 AM   #2
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
you can't do the itr or b16 IM without some cutting/welding/fabbing
just get a skunk2 one. it's better than the ITR one.
pills_PMD is offline   Reply With Quote
Old 05-12-2003, 04:01 AM   #3
Damn,
I just like OEM and wanted to stay pretty much OEM
Thanks
Old 05-12-2003, 12:22 PM   #4
the skunk2 looks oem anyways, it's not like an STR drag intake manifold or a sheet metal one. If you want to stay oem you could fit the ITR on there but like PillsPMD said you will have to do adjusting.
The one thing I can't figure out is if the ITR IM is so superior to the GSR unit why does Erick Aguilar use the GSR unit??
Milan
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 05-12-2003, 02:45 PM   #5
Rep Power: 44 MaaseyRacer is an unknown quantity at this point
Send a message via AIM to MaaseyRacer
uh i thought that guy used his own throtle bodies...
http://ericksracing.com/throttlebody.htm
2004 Toyota Tacoma
3.4L V6
TRD Package
4WD
MaaseyRacer is offline   Reply With Quote
Old 05-12-2003, 02:56 PM   #6
Rep Power: 0 Mark4135 is off the scale
his gsr manifold isnt a stock manifold i was down there the other day and i took a look and its weird it was sitting on the head there arent any butterflys in it and it also looks like he uses two spacers im sure that it has way more done then just that
Mark4135 is offline   Reply With Quote
Old 05-12-2003, 05:59 PM   #7
Of course it's not stock, it even says so on his website, I just wish I knew why he decided to use that style setup as opposed to the ITR style intake manni's. Maybe he designed it to create a lot of velocity?? Not sure
Milan
JGintake Manifold VS skunk2 intake manifo Teambypass Engine Building 26 04-08-2004 03:28 PM
B16a intake Manifold question Jdubspeeds General Tech and Maintenance 1 04-02-2004 11:35 AM
JDM VS USDM H22A ECU and intake manifold BenDejo ECU's, Electronics, and Tuning 2 03-11-2004 03:28 PM
Looking for 98 civic ex d16y8 intake manifold aaronblake98 Parts: For Sale/Trade/Wanted 2 02-29-2004 09:20 AM
EX intake manifold on a D series engine Liquidblaze General Tech and Maintenance 4 08-06-2003 07:02 PM
