Admin with a big stick
Ride: 2003 S2000
Rep Power: 379 ![]() ![]() ![]() |
The major difference is the final drive. The USDM ITR has a final drive ratio of 4.4:1, while the JDM ITR transmission has a final drive ratio of 4.785:1.
#8 |
Ride: 2003 S2000
The JDM ITR will give you the best acceleration, but you'll want to pick the transmission that allows you to reach the end of 4th gear by the end of the strip. If you're running a beefed up B block that will require you to shift to 5th before you run through the 1/4 mile, you might want to go with the USDM ITR. Of course, you can always fix that problem with taller tires....
How much money are you willing to spend? If you're going all out, get the JDM ITR and run taller slicks to get your final gearing right.
#10 |
Ride: 2003 S2000
The JDM ITR transmission fits the exact same as the USDM ITR transmission. All FWD B series transmissions bolt up the same way (maybe not the B20A).
