Just noticed something...
Old 07-06-2004, 01:14 AM   #1
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
I'm kinda confused, i dunno. I was just looking at the engine reference section and I noticed something...
B16A 1595 168@7800 116@7300 10.4:1 81 77.4 dohc yes 2 1996-2000 Civic VTi
B16A2 1595 160@7600 111@7000 10.4:1 81 77.4 dohc yes 2 1999-2000 Civic Si
If the bore/stroke/displacement are the same, how are the power levels different even if only by that 8 hp/5 ft lbs? Would it be because the VTi has (I'm assuming) a slightly higher lift vtec lobe on it's camshafts?
XBL: jams 8201 (14,730G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is offline   Reply With Quote
Old 07-06-2004, 01:53 AM   #2
Rep Power: 35 NotUrAverage_Si is off the scale
piston dome size is a little different.
and yeah vtecsir1, you're right the compression ratio is a little different also which is most likely created by the difference in the dome size of the pistons.
'00 <span style=\"color:black\">FBP</span> Civic <span style=\"color:red\">Si</span>-T
|<a href=\"http://www.full-race.com\" target=\"_blank\">full-race</a>|<a href=\"http://www.goldeneaglemfg.com\" target=\"_blank\">golden eagle</a>|<a href=\"http://www.fast-turbo.com\" target=\"_blank\">fast-turbo</a>|<a href=\"http://www.hondata.com\" target=\"_blank\">hondata</a>|<a href=\"http://www.wiredspeed.com\" target=\"_blank\">wiredspeedlab</a>|
email: boostfedEM1@yahoo.com
<div class=\'quotetop\'>QUOTE(dohch22a4 @ Sep 20 2004, 11:44 AM)</div><div class=\'quotemain\'> Please, Obi Wan B, you're our only hope.
</div>
<span style=\"font-size:36pt;line-height:100%\"> <a href=\"http://www.nissantech.com\" target=\"_blank\">www.NissanTech.co m</a></span>
NotUrAverage_Si is offline   Reply With Quote
Old 07-06-2004, 01:57 AM   #3
Rep Power: 43 vtecsir1 will become famous soon enough
jdm pistons have a higher dome, it has higher compression by .2 that should read 10.2:1 for the us version plus they run a higher octane in japan.
the c speed comp calculator
http://www.c-speedracing.com/howto/c...c/compcalc.php
vtecsir1 is offline   Reply With Quote
Old 07-06-2004, 02:07 AM   #4
2265787829
2000Si's Avatar
so it is 10.2:1 compression on the a2...? <_<
Old 07-06-2004, 02:18 AM   #5
Originally posted by revolution8k+Jul 5 2004, 11:07 PM--><div class='quotetop'>QUOTE(revolution8k @ Jul 5 2004, 11:07 PM)</div><div class='quotemain'> <!--QuoteBegin-vtecsir1@Jul 6 2004, 12:57 AM
so it is 10.2:1 compression on the a2...? <_< [/b][/quote]
yup.
</div>
Old 07-06-2004, 02:19 AM   #6
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Yes
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 07-06-2004, 02:34 AM   #7
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 569 E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
isnt the cam profile slightly different as well??
МОΛΏΝ ΛΑΒΈ
E_SolSi is online now   Reply With Quote
Old 07-06-2004, 02:44 AM   #8
2265787829
2000Si's Avatar
that's what I was asking.
