Facebook Twitter
lightweight flywheel pros and cons any input
This is a discussion on lightweight flywheel pros and cons any input in the General Tech and Maintenance forum
I would also like to add that my car actually shifts smoother with the 7lb because with less weight you don't have to be as careful to rev match, especially on the downshift. And I'm not getting any clutch chatter or any of that with ...
Old 08-07-2008, 07:29 AM   #26
caboose's Avatar
And I'm not getting any clutch chatter or any of that with mine
caboose is offline   Reply With Quote
Old 08-07-2008, 12:31 PM   #27
K2e2vin's Avatar
Originally Posted by caboose View Post
I was thinking that the CRX had a 16lb flywheel too
Two of the flywheels I measured were from 88 CRX's. Those, and the 94 EX and 88 Std all weighed the same. My brother's 93 CX was the one that was 15lbs, and the Accord flywheel I weighed came out of my 90 Accord LX.
I too am running a Fidanza flywheel(I thought it was 8lbs at first but had got it confused with my Accord; it's 7lbs). How smooth shifting is really depends on the clutch. I have no problems since I'm using an Exedy oem repclacement. With that said, it's still easier for me to drive smoothly with a heavier flywheel.
Groupon, sign up! http://www.groupon.com/r/uu16193153
1988 Honda Civic Standard-transmission build in progress!
1992 Honda Accord LX-DD
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 08-07-2008, 12:36 PM   #28
caboose's Avatar
Yeah, I think that 90% of people here are running more clutch than they need, so that's probably most of the issue.
I read a thread not too long ago where a guy was looking to buy a clutch and everyone said stage 2, but he bought a stage 3...wtf?
Stock/lightly modified engine=stock clutch!!
Old 08-07-2008, 03:56 PM   #29
Justin66's Avatar
Im pretty sure i have a stage 1 clutch, the guy told me is has a "heavier duty clutch", this is what happens when you buy a used car as we all know, never know 100%.
But i can tell it is cause i have used stock cars including a civic and my clutch is noticeably shorter and stiffer. I had trouble driving my friends Z24 cavalier because the clutch was soo long and i have a short throw.
Justin66 is offline   Reply With Quote
Old 08-08-2008, 05:54 AM   #30
YBLEGAL's Avatar
Generally speaking, if someone says "heavier duty clutch", that doesn't necessarily mean the flywheel was changed or the weight was increased or even decreased. That only means that the pressure plate has been upgraded with one of more clamping force, or possibly a segmented clutch disc.
- Just saying incase you didn't know.
Old 08-08-2008, 03:56 PM   #31
Justin66's Avatar
No i never said my flywheel was changed. But ya i know what you mean.
Old 08-19-2008, 12:04 PM   #32
Default Need advice
i have a B16A2 in my civic hatch and i am putting a stage 2 clutch in the place of the stock clutch.....the flywheel i am also putting in is 9.75 lbs and i need to know the good and the bad to make the best decision possible as to which flywheel i will use.....if it helps the stock flywheel is 18 lbs
Frenchapalooza is offline   Reply With Quote
Old 08-19-2008, 12:05 PM   #33
caboose's Avatar
Read this thread for starters...
Go as light as possible to get the most performance gain.
Old 08-20-2008, 01:00 AM   #34
YBLEGAL's Avatar
scroll up, duh
LS turbo vs. LS vtec turbo : pros and cons CRXSI91 Engine Building 55 01-15-2010 07:03 PM
Pros and Cons MoSeS Members' Lounge 17 12-19-2006 11:10 AM
pros and cons ls block vs gsr block civiclxb16 Engine Building 8 05-13-2005 11:20 PM
Pros / cons using the stock o2 sensor bung for you n2o_2k General Tech and Maintenance 4 07-23-2004 04:41 PM
some pros and cons of h22a swap into a civic cxjon HYBRID -> EG-EK / DC 0 09-28-2002 06:52 PM
© 2001-2013 HondaSwap.com
