Ls/vtec Booboo
Old 04-04-2003, 10:37 AM   #1
viciousracing
Guest
Posts: n/a
hey guys, somethin happen at the shop yesterday. my brother and i took his B18B head to the shop to drill in the knock sensor. the thing is, while we were watching, something happen. there was ping and pong and more aluminum came out than i suggested. the hole was deep. you guys know if it'll effect anything?
Old 04-04-2003, 12:22 PM   #2
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
Well your first problem is you are drilling into the head to add a knock sensor.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 04-04-2003, 04:39 PM   #3
Rep Power: 59 hcivic.com is on a distinguished road
do you have pics
hcivic.com is offline   Reply With Quote
Old 04-09-2003, 04:48 PM   #4
viciousracing
Guest
Posts: n/a
block i meant, it's pretty deep, i was like damn. knock sensor won't fit in too.
Old 04-09-2003, 05:16 PM   #5
Banned
Rep Power: 0 machine is off the scale
ouch
machine is offline   Reply With Quote
Old 04-09-2003, 05:24 PM   #6
Rep Power: 16 ryanwolfe911 is off the scale
Send a message via MSN to ryanwolfe911 Send a message via Yahoo to ryanwolfe911
Dude you should have drilled it by hand, and in a spot directly above the oil pressure sensor. That is a pretty thick area of the block. Or you could have just said screw all that and bought a Zdyne ecu that doesnt look for a knock sensor. Personally I just tapped an existing hole in my block for the sensor when I did it. It doesnt really matter where you put it at on the block, so long as it's there.
[color=red]If 4 out of 5 people suffer from diahrea, does that mean 1 person enjoys it?
ryanwolfe911 is offline   Reply With Quote
Old 04-10-2003, 11:38 AM   #7
viciousracing
Guest
Posts: n/a
i fixed it by adding a thread to the hole, then added a plug into it, and then on the other end of the plug added the knock, you guys think this is a good idea?
I'll draw pix for you guys.
Old 04-10-2003, 12:23 PM   #8
Rep Power: 47 liquid00meth is off the scale
Send a message via AIM to liquid00meth
sounds reasonable. I would make sure your filler plug is made out of something that isn't going to be prone to heat damage (ie plastic melting)
"Our enemies are innovative and resourceful, and so are we.
They never stop thinking about new ways to harm our country and our people, and neither do we."
-The thought provoking George W. Bush
liquid00meth is offline   Reply With Quote
Old 04-10-2003, 01:03 PM   #9
Yeah , so long as it works, then fuck it. I would however, try to use a plug made out of aluminum so that the metals would expand and contract at the same rate. Just make sure it doesn't leak. I would like some pics though
Old 04-10-2003, 02:55 PM   #10
viciousracing
Guest
Posts: n/a
you know what type of aluminum would it be on the block? 6061?
Old 04-10-2003, 04:55 PM   #11
Rep Power: 15 Viperlocc_B18C1 is off the scale
Send a message via ICQ to Viperlocc_B18C1 Send a message via MSN to Viperlocc_B18C1 Send a message via Yahoo to Viperlocc_B18C1
or you could have been like me and just not use the knock sensor
1994 Black Civic HB - 5spd, GSR swap, GSR interior, GSR brake swap, CTR pistons, Stage 1 head, AEM CAI, LS Rims, Tanabe Exhaust, Tokiko 5way adjustable shocks, Coilovers - FASTEST TIME - N/A (soon)
Signatures are NOT allowed on HS. PLease don't not put this pic back in. Mod
Viperlocc_B18C1 is offline   Reply With Quote
LS/Vtec turbo? UDT General Tech and Maintenance 5 11-20-2003 10:53 AM
ls/vtec werd KWJaY Engine Building 11 09-10-2003 05:39 PM
ls/vtec integra silverfox HYBRID -> EG-EK / DC 5 06-30-2003 11:00 AM
Keep Gsr Or Go Ls/vtec TegraTuner HYBRID -> EG-EK / DC 3 05-15-2003 10:13 PM
Ls/vtec Or Ls/t ? WhItE90CRX General Tech and Maintenance 2 04-10-2003 05:03 PM
