Main Relay Clicking?
Old 03-11-2003, 10:38 AM   #1
Ride:  '92 Civic CX
Rep Power: 37 D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
while i am driving, my engine hickups and at the same time my main relay is making a clicking noise. it does this randomly. there is nothing i can do to make it do this.
i already know that the main relay controls the power for the ecu, fuel pump, and injectors. so my quesion is, what would make the main relay do this?
-i have already got a manual and followed the procedures for checking the main relay and it works fine.
-i have already got another pr3 ecu that i know works fine and it still does the same thing.
?could a bad fuel pump cause this?
?could a bad ignition switch do this?
any help or a point in a direction would be greatly appreciated.
Garage:
1992 CX Hatch > Current Money Pit
Grave:
R.I.P. 1995 Integra GSR
R.I.P. 1990 DX Hatch
R.I.P. 1990 CRX Si
D See 2 is offline   Reply With Quote
Old 03-11-2003, 11:06 AM   #2
Rep Power: 12 sirkurtius is off the scale
the main relay should only click once[ when you turn on the car] but if can hear the main relay click over the sound of your fuel pump priming then there is a problem with main relay, u should replace it before the car won't start at all
sirkurtius is offline   Reply With Quote
Old 03-11-2003, 11:11 AM   #3
i take it your car is a crx, main relays are c ommon problem with car that are that old so don't worry its a simple fix, its not only crx 's its all honda's, when u get the new part take the old one apart and u will see brown residue all around the circut board
Old 03-11-2003, 11:48 AM   #4
Ride:  '92 Civic CX
thx for the replies. i've searched google before and have already unsoldered and re-soldered all of the pins on the PCB and have tested it according to manufacturers specs. everything works fine and there is continuity through all circuits where it should be. plus i got another one out of a junk yard and it still does the same thing.
is it possible for a bad fuel pump to cause this?
Garage:
Grave:
R.I.P. 1990 CRX Si
Old 03-11-2003, 01:18 PM   #5
Ride:  '92 Civic CX
has anybody had a fuel pump go bad before? what was it's symptoms?
Garage:
Grave:
R.I.P. 1990 CRX Si
Old 03-11-2003, 02:30 PM   #6
CRX-YEM's Avatar
Ride:  91 CRX
Rep Power: 69 CRX-YEM is a splendid one to beholdCRX-YEM is a splendid one to beholdCRX-YEM is a splendid one to beholdCRX-YEM is a splendid one to beholdCRX-YEM is a splendid one to beholdCRX-YEM is a splendid one to behold
Send a message via ICQ to CRX-YEM Send a message via AIM to CRX-YEM Send a message via Yahoo to CRX-YEM myspace
I just recently had an ignition coil burn out on me. gave me intermittent problems for months till it finally just shit the bed and shorted to ground.
took my battery with it as well.
Dennis
Please don't PM/Email/IM me for technical support. Make a Post!!!
91 CRX DX, 03 Civic EX
"There are 10 kinds of people in the world: those who get binary and those who don't."
"Of all my imaginary friends I don't think there was one I didn't end up having to kill"
CRX-YEM is offline   Reply With Quote
Old 03-11-2003, 02:50 PM   #7
Ride:  '92 Civic CX
what was the symptoms you were having before it completely went out on you?
Garage:
Grave:
R.I.P. 1990 CRX Si
Old 03-11-2003, 09:28 PM   #8
Rep Power: 14 farmer_jason is off the scale
Send a message via Yahoo to farmer_jason
check the main ground on the thermostat housing a friend of mine left his loose and it did the same thing sometimes it would click repeatedly. or gound from bat. ground to tranny
farmer_jason is offline   Reply With Quote
Old 03-11-2003, 11:07 PM   #9
Ride:  '92 Civic CX
thx y0, i'll check into that.
Garage:
Grave:
R.I.P. 1990 CRX Si
Old 03-11-2003, 11:40 PM   #10
Ride:  CIVIC B20Z2 VTEC
Rep Power: 14 thetoymaker is off the scale
Send a message via Yahoo to thetoymaker
my crx did something similar to that, it turned out to be the chasis ground had rotted out, check that.
Was that fast?
thetoymaker is offline   Reply With Quote
Old 03-11-2003, 11:54 PM   #11
Ride:  06 Chevy Silverado
Rep Power: 74 Jeef is a splendid one to beholdJeef is a splendid one to beholdJeef is a splendid one to beholdJeef is a splendid one to beholdJeef is a splendid one to beholdJeef is a splendid one to behold
Send a message via AIM to Jeef
My Civic did the same thing. Ill have to check the grounds in it.
Ex 89 crx si,91 & 95 Civic owner.
06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap.
Jeef is offline   Reply With Quote
Old 03-13-2003, 12:22 PM   #12
Ride:  '92 Civic CX
thanks for all of the help on this subject fellas. it's supposed to be nice this weekend so i'll look into it. my main brain buster is... why the hell does the main relay click if it is just a ground?
could a faulty distributor igniter cause this.
Garage:
Grave:
R.I.P. 1990 CRX Si
Old 03-14-2003, 09:50 AM   #13
Banned
Rep Power: 0 sportlinecrx is off the scale
my engine had that hiccupping problem. it was my igniter. i didnt hear any clicks, but i always had my radio on or there was noise from outside.
and FYI, the igniters in the 4th gen civics were recalled by honda. seems like nobody here knows this, cause we are all second or third hand owners of our hondas...except me
BTW, after awhile, my engine was dying AT SPEED on the freeway. it started as little hiccups, but after a few weeks, the car would often not start, even with a jump and the car was dying at least once on every trip. i wouldnt have let it go so long, but it took forever to figure out what it was.
sportlinecrx is offline   Reply With Quote
Old 03-15-2003, 06:39 PM   #14
Rep Power: 0 turbonewf is off the scale
realy flutter is most always caused by a bad ground.... check the wiring. like was said the thermostat housing is a good one.
turbonewf is offline   Reply With Quote
Old 03-15-2003, 07:47 PM   #15
Ride:  '92 Civic CX
well i put a new igniter in it today and it does the same fucking thing. DAMNIT. it is really starting to get on my nerves. i'm going to check ALL grounds tomorrow wether permitting. what are all of the major grounds i should check?
Garage:
Grave:
R.I.P. 1990 CRX Si
Old 03-16-2003, 10:55 PM   #16
Rep Power: 12 enemycivic is off the scale
sorta confused but when you turn the key does it go click click click really fast! I would just check the negitive battery cable shake it around and then try and start the car? just another thing to check on your checklist o things
enemycivic is offline   Reply With Quote
Forum Jump
ECU Pinouts pissedoffsol Reference Materials 4 11-21-2007 10:46 AM
CRX MAIN RELAY AND FUEL RELAY CReX123 HYBRID -> ED-EF / DA 4 07-30-2004 03:04 PM
88-91 Main Relay Location brian11to1 ECU's, Electronics, and Tuning 12 07-13-2004 02:54 PM
Main relay clicking Jeef General Tech and Maintenance 12 06-09-2004 06:17 PM
Main Relay Q ? CRX-YEM ECU's, Electronics, and Tuning 7 01-22-2003 07:47 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
