Ok my car have been boggin quite sometime now. I know i have a loose ecu pin but can it also make my car bog?I'm either thinkin that it could be my fuel pump , bad distributor or loose ecu pin. I alredy changed the fuel filter, spark plugs, cap n rotor all that ignition stuff. What could it be? Thanks
first of all what is your car, what are you running for setup? Its pretty hard for any of us to answer a question aout a bog on an imaginary car. you have to be a little more informative then we will gladly help u
94 Honda Accord, jdm h22 swapped daily driver 04 cbr600rr fun toy 95 toyota tacoma, lifted winter truck |
FYI you havent replaced all the ignition stuff there is a sensor inside the dizzy that tells TDC and a few otehr things, you haven't and wont be able to replace that... are you throwing any codes. What octane, is it a JDM engine, air filter dirty/clogged? The basics man, try that then go looking for bad pieces.
90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! |
#5 | |
#7 |
the sensor im talkin about is built into the dizzy... it's the TDC-top dead center/CYP-cylinder(SP?) position sensor/CPS-crank position sensor these are used for Timing purposes... If it is gettin a code 15 that's what's wrong, the Dizzy is bad i got a code 15... it cost me 75 for a new one...
here's your code... Code 21*- Accord Civic CRV CRX Del Sol Odyssey Prelude 94-98 ** 92-95 n/a n/a 93-95 n/a 93-95 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve * not a valid code if car does not have a VTEC engine ** not with V-6 engine __________________
#8 | |
#9 | |
#10 |
Iam lost my 88 prelude 5 speed Bogs ( drives and then dies due to lack of gas sputtering the dies then starts again maybe drives then die) i have replaced fuel filter duel pump air filter plugs 2 months ago I cut the catalitic converter off to see if that was the problem. The programmed fuel injection makes a hissing noise when i turn key half ways when only pump is running please some any ideas |
| H22a swap bogs | 92vegaslude | HYBRID -> BA-BB /CA-CD | 2 | 03-26-2004 07:54 PM |
| My car bogs out sometimes... | scottp11 | HYBRID -> EG-EK / DC | 23 | 03-24-2004 11:36 PM |
| Car bogs down when vtec should start | eastkoastkustumz | HYBRID -> EG-EK / DC | 0 | 02-24-2004 12:19 PM |
| 1988 prelude engine bogs | justing | General Tech and Maintenance | 1 | 10-24-2003 11:26 PM |
