my car sucks.
Old 06-15-2005, 12:17 PM   #1
Rep Power: 15 Pewble is off the scale
Send a message via AIM to Pewble
yea so my car started overheating bad. so i drove it like a total of like 1 hr 15 min while the temp gauge was high. I added coolant and drove more i got like 40 minutes before it got super ultra hot then still drove it a bit. its been like 5 weeks sitting in my driveway and i put a new radiator in cause the old one is super caked with minerals. i used de-ionized water and water-wetter this time. ( and coolant of course ) well now i started my car and it smokes from the engine bay right away. ( 95 DX Coupe... ) Looks like a piece of rubber real close to my timing belt and head gasket is peeling out of the engine. i pull on it and it feels like its coming out really close to the timing belt/ head gasket. dont know if this is the head gasket or what.... i dont really want to fix it i think i would rather swap to some other motor please help... i dont have much $$ either i take the bus to work right now!!!
Pewble is offline   Reply With Quote
Old 06-15-2005, 01:45 PM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
if you ran the car for an hour and a half when it was suepr hot, you probably broke something, pooped the head gasket, or metled something.
Old 06-16-2005, 01:33 AM   #3
Rep Power: 17 B16CRX is off the scale
Send a message via AIM to B16CRX
how the hell did your car remain hot while you were driving? you must have a clog somewhere in your coolant lines/flow. Your first mistake was driving it hot like that. might as well have driven without oil.... you say the rubbery thing is near the timing belt? sounds to me liek the gasket for the timing belt cover, but I really had a hard time understanding what you were describing.
1991 CRX Si
PR3 B16A
62mm BBK TB
Boosted
B16CRX is offline   Reply With Quote
Old 06-16-2005, 01:42 AM   #4
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
Well... I think it's just about time you swap a B series into it.
XBL: jams 8201 (14,580G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is online now   Reply With Quote
Old 06-16-2005, 02:59 AM   #5
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Check your thermostat. Theres a rubber seal around it that in time, deteriorates and can cause sticking. Be sure and bleed the system, as B said air bubles cause it to overheat. As far as what's oozing out from between your head and block, er don't know, head gasket isn't rubber, are you sure it's between the block and the head, and not the valve cover gasket?
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 06-16-2005, 03:55 PM   #6
dang nabbit i guess im getting the motor put back together again. i wish i could afford b series....
