Greenhorn
Ride: EK4 & DC2 project
Hello all, im new, i used to use a UK forum called hondaevolutions for the technical side of things, but since the forum has died i thought id see how i get on here as most of the time i google anything technical i need to know i end up getting linked here.
Basically my EK4 has on occasion blown out some blue smoke on startup and from what i can see while driving in the mirror (only at night in the headlights of other cars) it smokes more than i am happy with when im 'giving it some', friends who have been behind say there is a bit of smoke but no more than normal for a vtec, im not too sure though. From what reading i have done the startup smoke will be valve stem seals and the smoke while racing is piston rings. The car seems to have used alot of oil in a fairly short space of time and there seems to be some oil on the block only below the headm would it make sense to replace the head gasket too? I want to do all this without removing the engine, is this posible? Are there other things i should replace while im there eg timing belt? Sorry there's alot there but any help much appreciated..... Thanks in advance Aaron |
| Smoking | GSRCoupe09 | Engine Building | 5 | 07-17-2009 01:31 PM |
| car STILL smoking | b16coupe | General Tech and Maintenance | 3 | 07-11-2005 12:15 AM |
| 20-30K to run 11s? WTF ARE YOU SMOKING | jeffie7 | Members' Lounge | 17 | 07-27-2004 07:32 PM |
| smoking crx | PHOBIA | General Tech and Maintenance | 2 | 05-02-2004 02:44 AM |
| What to do?? smoking | importstyle | General Tech and Maintenance | 3 | 11-06-2003 02:03 PM |
