My Engine is Missing around 3000RPM
Old 07-10-2003, 08:24 PM   #1
Dustin_m's Avatar
Ride:  2001 Jeep Cherokee
Rep Power: 83 Dustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud of
myspace  FaceBook
It seems like ever since i did a regular tune up on my rex, it misses around 3000 rpm. Its only when i hold it around there or i'm accelerating slowly, not when i'm driving normally. There are only two things i can think of that might be the problem- either i didn't gap the plugs right, or the dist. rotor doesn't work, since i didn't change it cuz it's fuckin hard. maybe those things don't have anything to do with it, i don't know. BTW my motor is the D15 and has about 190,000 miles.
thanks
Originally Posted by E_SolSi View Post
frankly ill be surprised if you ever form a post that doesn't read like you are wearing a hockey helmet chewing on a box of crayons drooling all over yourself while you lick the fucking monitor and mash away at the keyboard
My Photostream on Flickr
Dustin_m is offline   Reply With Quote
Old 07-10-2003, 09:21 PM   #2
Rep Power: 18 Riceburner is off the scale
Send a message via ICQ to Riceburner Send a message via MSN to Riceburner Send a message via Yahoo to Riceburner
Talking
well i think its your dis. coil..plus there a spring in your dis. that sometimes jumps...check your dis. coil if that dont work try checkin your plugs and make sure there in the right place...my EX did the samething...would jump and spurter around 4k..hope this helps ya out man..
Riceburner is offline   Reply With Quote
Old 07-10-2003, 09:22 PM   #3
Rep Power: 17 word is off the scale
same problem here and i've been asking about this for awhile, no replies so far.
i have a CEL for IAV sensor and I'm not sure if it has to do with anything.
anyone else had this problem?
<a href=\'http://www.hondaswap.com/gallery/browse.php?album_id=521\' target=\'_blank\'>2.0L naturally aspirated goodness</a>
Georgia Institute of Technology Class of 2004
word is offline   Reply With Quote
Old 07-10-2003, 09:50 PM   #4
Ride:  94 Integra GSR
Rep Power: 31 brc80 is an unknown quantity at this point
Well shit ill jump on the bandwagon too, when im at part throtle or accelerating slowly i get the same thing like its missing, but if i nail it, it clears right up and drives fine, if anyone knows please help me, its pissing me off.
1994 Acura Integra GSR
Power:
AEM V2 Cold Air Intake
GReddy 4-2-1 Header
GReddy Evo 2 Exhaust
Suspension:
Tanabe Sustec Pro S-0C
brc80 is offline   Reply With Quote
Old 07-10-2003, 11:41 PM   #5
distributor!!
Old 07-11-2003, 12:06 AM   #6
does this mean i could check/fix it myself? or have it rebuilt/buy a new one?
its a bitch to drive with the problem, when i dont pay attention i get that jerking with the clutch engaged.....feels like the engine's gonna rip out of the mounts.
thanks!
I've always thought it was one of my CEL's because I have CELs up the wazoo.
Old 07-11-2003, 02:17 AM   #7
Rep Power: 17 noobvang is off the scale
Try putting some of them electric grease on all the electrical connection.
At the ignition coil connector (the + and - wires), coil spring, plug wire boot terminal, spark plug termial connector.... anywhere that has an open metal connection.
Had the same proplems too, did this an it fixed it.
96 LX 4dr. with B18a, PR3 pistons, B16 head w/ port 'n polish to intake, CTR intake/exhaust cams, ITR IM, CTR TB, Hondata IM gasket, RC 310cc injectors, Denso Iridum plugs, Skunk2 valve springs/retainers, Excedy race clutch, ACT streetlight flywheel, Walbro 255 fuel pump, GSR tranny, and Tanabe Super Racing Medalion...., next is Header and VAFC.
Best run on 1320:
14.5 @ 94.5mph street tires
14.4 @ 94mph small slicks :P
98 Yamaha R1
noobvang is offline   Reply With Quote
Old 07-11-2003, 03:28 AM   #8
Banned
Rep Power: 0 sportlinecrx is off the scale
change your rotor! my crx was missing at and above 3k for about 2 weeks, then i changed the cap and rotor...and that fixed it. should also change your spark plug wires.
if the gaps on your plugs are too big, it will just kill your engine's power and make it feel really sluggish.
sportlinecrx is offline   Reply With Quote
Old 07-11-2003, 04:27 AM   #9
another question from the electrical idiot:
are there any differences between OEM rotors/cap, aftermarket (autozone) rotors/cap, and say MSD and Crane stuff?
I understand MSD and Crane caps have a extra plug for their coil blasters or whatever its called, and I understand it's not needed unless I am pushing holy amount of power out of the 1.6 where my spark isn't enough. I always thought it was just a BS upgrade for the average hondas, much like the fuel rails.
also, noobvang, i know where the + and - are, but what does a coil spring look like? I've never had the guts to mess around with a distributor, those things are kinda expensive.
thanks for all the help.
Old 07-11-2003, 04:30 AM   #10
rixxxceboy,
I (and the other 2 members) are only missing around 3000 under very light throttle. I can drive around all the time with more than 50% throttle and it never misses.
do you think it could be the cap & rotors?
i'm a little excited because all the dumbass shops around here have no idea what's wrong, they kept telling me its the fuel system, now i can finally get it fixed
Old 07-11-2003, 01:15 PM   #11
The coil spring is the one that acutally touches with the dist. cap. It should be located at the end of the extending arm from the coil.
Change the cap and rotors first. Then if it still does this, then use my method.
Best run on 1320:
98 Yamaha R1
Old 07-11-2003, 01:46 PM   #12
B16
B16's Avatar
i've wondered the same thing...
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 07-11-2003, 07:59 PM   #13
try replacin the coil...
Old 07-13-2003, 03:50 AM   #14
Banned
Originally posted by word@Jul 11 2003, 03:30 AM
rixxxceboy,
hmm no then. the harder i accelerated, the more it missed. if its not missing whjen you give it alot of gas, then yes, its probably a fuel delivery problem. have u tried replacing your fuel filter? that would be the first thing i'd do.
Old 07-14-2003, 10:03 AM   #15
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
oxygen sensor. end of story .. mine was doing the same thing at partial throttle, i put a new one in and problem fixed.
pills_PMD is offline   Reply With Quote
Selling MANY various Civic engine parts! oakley2002@cox.net Parts: For Sale/Trade/Wanted 7 02-20-2008 03:31 PM
cx with d16z6 engine rev problems crxsi HYBRID -> EG-EK / DC 1 09-28-2006 12:06 PM
light weight engine SolPWR Members' Lounge 31 12-11-2003 05:09 PM
ecotec tweakman Members' Lounge 22 09-29-2003 03:23 AM
Which Engine Help Me Pick! fwddrag HYBRID -> EG-EK / DC 12 04-02-2003 12:43 AM
