my sol is dead
Old 12-24-2002, 11:48 AM   #1
Rep Power: 50 micah is on a distinguished road
Send a message via AIM to micah Send a message via MSN to micah Send a message via Yahoo to micah
ok a while ago my car quit starting, it wasnt a gradual thin it just wouldnt start one day.
i can still push start it and maybe 5-10% of the time it will start normally, but the rest of the time it doesnt it just whines like it wants to but it never clicks in.
i took the starter/selinoid to one place and told them to take it apart and check it out, they said everything was fine. put it back on my car and it still wouldnt start. my dad told me the starter might not be getting enough juice from the battery because my battery was old and i needed a new one anyway so i bought a new battery and it still wont start. i have since then taken the starter to a dif place that tested the starter and the selinoid and said both worked perfectly and i have put new battery cables/clamps on.
the bastard still wont start and im out of ideas.
anyone know what the hell could be wrong?
also after push starting it for a week or so it started having a rough idle it would bounce between 1-2k not fast, but a slow steady rise and fall of rpm's.
god called in sick today
micah is offline   Reply With Quote
Old 12-24-2002, 12:15 PM   #2
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
b16 sol if i remember correctly right?
so it is cranking though?? perhaps it isn't getting fuel ? maybe the distributor isn't firing.. there could be so many things..
pills_PMD is offline   Reply With Quote
Old 12-24-2002, 12:21 PM   #3
Rep Power: 22 Hexen is off the scale
Send a message via ICQ to Hexen Send a message via MSN to Hexen
Check the coil in your distributor.
I had a somewhat similar problem in my D16z6.
But I never resorted to push starting my car.... I just bought a new distributor coil and put it in.
Actually I bought EVERY FREAKING PIECE of the distrubutor before I bought the coil, and put them all in. And it ended up being the coil.
<span style=\'color:red\'>1994 Honda Civic EX (stock)</span>
<span style=\'color:black\'>1995 BMW M3/2</span>
Hexen is offline   Reply With Quote
Old 12-24-2002, 01:08 PM   #4
Rep Power: 18 zueke is off the scale
Send a message via AIM to zueke
Could it be the fuel pump is broken or possibly just a blown fuse for the fuel pump?
zueke is offline   Reply With Quote
Old 12-24-2002, 07:48 PM   #5
yeah pills you remember right a b16...
i got sick of reregestering when the forums was having all the problems so i just never did the last time till now ;p
i dont see how it could have anything to do with the fuel injection system, if it was that then psuh starting it wouldnt work.
ive also checked the flywheel, i just eyed it over but it looks fine, it isnt missing any teeth or anything.
ill check on the distributor coil
Old 12-25-2002, 12:46 AM   #6
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
if you can pop-start it, its not your distributor.
you need a starter
Old 12-25-2002, 12:50 AM   #7
Rep Power: 83 Havok is an unknown quantity at this point
Send a message via AIM to Havok
W00t, micah is back! Yeah, a black B16 Sol Si... on the starter, but what about Alternator, was it dying before it stopping starting, or did it run perfect before that?
My skin is singed but it heals my heart
and with glowing pride I'll wear my scars.
I'm honored by your hatred!
She wanted love, I taste of blood.
She bit my lip and drank my warmth from years before.
Havok is offline   Reply With Quote
Old 12-25-2002, 02:43 AM   #8
Rep Power: 17 chevy302dz is off the scale
Check the fuel pump to see if it's priming the system. Put the key in the on position and then go to the back of the car and listen to see if you hear the pump running it should stay on for several seconds
</span><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (Pissedoffsol @ Posted: Apr 15 2003, 12:35 AM)</td></tr><tr><td id=\'QUOTE\'>killing a saturn is like beating off and calling it sex</td></tr></table><span class=\'signature\'>
chevy302dz is offline   Reply With Quote
Old 12-25-2002, 10:37 AM   #9
heya afipunk ;p
alternator is fine, everything ran perfect before hand...
once again i dont think its anything to do with the fuel system, but ill try it out, thnx for all the help guys...
now to post about my dead rex
Old 12-25-2002, 11:03 AM   #10
http://www.hondaswap.com/forums/index.php?...t=ST&f=2&t=3532
Old 12-26-2002, 09:41 AM   #11
well i talked to a mechanic friend that stopped by for christmas and he said sometimes starters are just gay like that and every once in a while he has to shave off some of the casing so that it will poke out more and engage the flywheel.
anyone ever heard of/reccomend this?
id rather do that than buy a new starter. has anyone here ever looked up the price of a 94 sol DOHC VTEC starter? its not pretty.
Old 12-26-2002, 05:30 PM   #12
Banned
Rep Power: 0 sportlinecrx is off the scale
a few things to check/replace.....
main relay
starter relay
igniter (inside distributor)
those are some things i know can cause the problems u are having. good luck!
sportlinecrx is offline   Reply With Quote
Old 12-27-2002, 11:35 AM   #13
will check it out
thnx!
Old 12-27-2002, 12:34 PM   #14
B16
B16's Avatar
definately not a fuel problem, i say its the starter
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 12-27-2002, 02:27 PM   #15
RETIRED
starter is easy... you can use any- b-series dude
browse honda-tech classfieds... theres always shit like that in there
Old 12-28-2002, 11:20 AM   #16
well i was quoted a starter for like 200+ bucks
id hate to spend that on a new starter if its not the starter. i mean 2 places have tested it and said its fine
Old 12-29-2002, 04:16 AM   #17
Rep Power: 24 djextremity is off the scale
Send a message via AIM to djextremity
Bad connections to the starter perhaps?
djextremity is offline   Reply With Quote
Old 12-29-2002, 04:20 AM   #18
RETIRED
i hear ya man...
shit, at this point- it might be worth the money to hit up the dealership and get a $78 dignostic run...
Old 12-29-2002, 01:50 PM   #19
well the car has been sitting at my dads because he was having some of his friends look at it and because one of the damn tires blew out
so at the moment im buying 2 new tires for the back then getting the bastard back here and as far as im concerned ill push start it for the rest of my life. hell starters weight too much anyway :P
a diagnostic run is prolly my best bet. getting a day off work is the only problem
Old 12-30-2002, 01:16 AM   #20
Rep Power: 0 Bakeoff is off the scale
What does it do when you turn the key? Click, crank and not fire? If it's just clicking, or not doing anything at all, a diagnostic run won't do jack. It's something between the key and the starter. You could have a bad ignition switch... Definitely something with the starter...
Bakeoff is offline   Reply With Quote
Old 12-30-2002, 01:23 AM   #21
Shit I can take it to Marshall Honda for you, I work like 3 days a week
Old 12-30-2002, 09:57 AM   #22
when i turn the key it whines and acts like its wanting to turn but it doesnt every once in a while it will click, just wont ever fire
Old 12-31-2002, 06:35 PM   #23
Rep Power: 0 bluepearl_integra is off the scale
check your fuel pump. on honda engines one thing that seems to happen is that the valve on the inside of the fuel pump will get stuck sometimes. but u sound like you need a new one. get it checked out
later
bluepearl_integra is offline   Reply With Quote
Old 01-05-2003, 08:54 PM   #24
ok, another question.
the starter for my motor is rated at 130 amps, but when mine was tested it was only pushing 120 amps. they said it was still good, but im just owndering if that 10 amps will keep it from starting. the nonvtec version is only rated at 120 amps.
also i failed to mention before but i just thought about it today, but when i first started pushing off my car every once in a while when i was driving the motor would make an awful screaching sound. friendof mine told me it sounded like the starter was trying to engage while the motor was running.
figured that might help diagnose the problem.
thnx guys
Old 01-05-2003, 09:09 PM   #25
Rep Power: 15 flippedcivic95 is off the scale
Send a message via AIM to flippedcivic95
check the main relay beleive me mine did that oh yea and its locatedunder the dash on the driver side
flippedcivic95 is offline   Reply With Quote
dead battery? b16coupe General Tech and Maintenance 11 03-11-2005 02:28 PM
EVIL DEAD REMAKE!!! adnoh Members' Lounge 10 12-05-2004 04:39 PM
Dead whale MaaseyRacer Members' Lounge 20 03-29-2004 11:38 PM
Beating A Dead Horse I Know... Magik Wheels / Suspension / Tires / Brakes 9 03-10-2004 10:06 AM
