Are my Synchros going bad
Old 10-13-2004, 09:12 PM   #1
Rep Power: 11 THEUSED is off the scale
My tranny keeps falling out of gear in first and second gear at low rpms but never in the other gears no matter how low the rpms are, and when Im in third at low rpms I can move it out gear without using the clutch,
Are my synchros going bad or is my clutch going out ?
THEUSED is offline   Reply With Quote
Old 10-14-2004, 01:37 PM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
you can move a shifter in and out of any gear without a clutch. thats what synchros do.
if your synchros were bad, you're grind going into the gear, even with the clutch depressed.
the shifter popping out is not clutch related. if your clutch was bad, you would rev up with it in gear, but not go anywhere (the clutch would be doing a burnout, so to speak, instead of holding and moving your forward.)
Old 10-14-2004, 09:45 PM   #3
Rep Power: 14 Arachnid is off the scale
could be a bent shifter fork or defective mounts.
Arachnid is offline   Reply With Quote
Old 10-16-2004, 04:17 AM   #4
Rep Power: 14 odnet is off the scale
Send a message via AIM to odnet
3rd gear is a little rough for me right now, it grinds going in if I'm over 2500, and once a week or so it'll kick it out if I'm running under 2000.
odnet is offline   Reply With Quote
