need help with buying '93 canada made si hb
Old 11-12-2002, 04:00 PM   #1
Rep Power: 15 The_MATRIX is off the scale
Unhappy
Im looking to buy this 93 si hb but the info I get is that it doesn't have vtec?
I thought all the 92-95 si hb were vtec?
Also, it is canada manufactured/sold and wanted to know if that matters, or if the info I have is wrong and it is vtec.
Also, if someone has a carfax account and could run the vin for me I'd appreciate it
vin# 2hgeh3380ph537637
it has 132k/mi replaced timing belt, and is in pretty clean shape, the guy is asking $3,600 for it, it was driven by his wife and has been babied
the only prob is dented / f**ked up hood and headlight (will replace with carbon fiber & projectors
Thanks in advance for helping out this (soon to be) first time honda owner
Chris
Chris_brainerd@yahoo.com
The_MATRIX is offline   Reply With Quote
Old 11-12-2002, 04:02 PM   #2
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 99 dohcvtec_accord is an unknown quantity at this point
If the valve cover says VTEC, it's VTEC. If not....well, you know the deal.
This space left intentionally blank.
Old 11-12-2002, 04:44 PM   #3
Rep Power: 24 djextremity is off the scale
Send a message via AIM to djextremity
if you're in canada, your si is equivalent to our dx i believe. that would mean that the si has a d15b7 i think and does not have VTEC. it would be an SiR that has VTEC for you.
djextremity is offline   Reply With Quote
Old 11-12-2002, 04:46 PM   #4
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
If it was sold new in Canada, it's not the equivalent of a USDM Si hatch. The Canadians got a slightly different trim level scheme... their Si coupe is our EX coupe, and their SiR is our Si. I guess if you can go one trim level 'below' the USDM Si, that's probably what the Canadian Si is. I don't know which trim that would be though... I assume DX.
Old 11-12-2002, 04:54 PM   #5
yeah what i said =]
Old 11-12-2002, 05:28 PM   #6
Rep Power: 23 chet is off the scale
Send a message via AIM to chet
just check the motor, look for a vtec solenoid.
check for rear disc brakes, check for sway bars, check for a clock, check for a tachometer...they're are many differences between dx's and si's and vx's/cx's.
if it has rear discs and a tach, chances are its a single cam vtec.
<a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a>
chet is offline   Reply With Quote
Old 11-12-2002, 07:07 PM   #7
get this, rear disc w/tach no-vtec emblem on valve cover...
shucks
Im not really too worried about it though, I'm eyeing a 94 RS teg right now its the teg, the hatch, or a civ (94 ex coupe)
any opinions?
Old 11-13-2002, 12:11 AM   #8
Rep Power: 0 dahracer is off the scale
Some 92-95 Si's have no vtec valve covers. Mine is a 93 si vtec and have no vtec written on it. And as far as I know, all si's come with 14" rims the dx's are 13s. Also all si's as far as I know come with Sunroofs. And if u really wanna know what engine u have check it on the block on the left side above the tranny.
dahracer is offline   Reply With Quote
Block Filling K2e2vin Engine Building 28 02-16-2005 12:11 AM
Ok.....Time for Canada to REPRESENT!!! adnoh Canada 15 08-23-2004 02:04 AM
Home Made Turbos For Zc ? starboy869 General Tech and Maintenance 1 03-24-2003 09:30 PM
