new cam and aem cam gear but can't get timing right please help
Old 11-05-2009, 10:37 PM   #1
Greenhorn
Rep Power: 0 racejunkie is on a distinguished road
Default new cam and aem cam gear but can't get timing right please help
hello all,
i have a 90 civic si with the d16a6. I purchased an exospeed reground stage 2 cam and an aem adj cam gear. I replaced them a year ago and haven't started the car yet. (wainting to paint the car). Now that I'm trying to get the car running, the car won't start. I remember having a hard time when I replaced them becasue the old stock cam gear has the notch for tdc. But the new gear didn't have it.
Anyone out there know how to get the car timed right. I checked my firing order, and reversed the distributor thinking it could be 180 out. But still nothing. I do have spark and have replaced the plugs and put new gas in it (parked it with fumes). I also tried using starting fluid. Not even a sputter. My only thoughts are that when I installed the belt the head wasn't in tdc (the bottom end was at tdc #1 cyl).
How do you know when the head/cam is in tdc?
Please Help!!! and thanks!!!
racejunkie is offline   Reply With Quote
Old 11-09-2009, 09:01 PM   #2
Greenhorn
anyone?
Old 11-14-2009, 01:34 AM   #3
rkwoos12's Avatar
Ride:  94 honda civic ex 5 speed
Rep Power: 8 rkwoos12 will become famous soon enoughrkwoos12 will become famous soon enough
well first off your distributor should only go in one way so you shouldn't be 180 out unless you forced the distributor on there, another thing is that your head i think may have marks on each side and your new adj. cam gear should have two marks on each side showing the two marks your suppose to line up with your head and your crank will have marks on the gear with the block line then up make sure when you making sure when you check the belt that the timing marks are not off by a few teeth. there are free manuals on the web where you can download the manual for free and you can check to make sure that what im telling you is correct.
hope this helps if not use google helped me out a lot when needing diagrams and stuff.
rkwoos12 is offline   Reply With Quote
Variable Cam Timing - aftermarket cam gear? charleskwinter General Tech and Maintenance 7 01-22-2008 01:36 AM
WTT/WTB OBD2 H22 timing gear for OBD1 Bird333 Parts: For Sale/Trade/Wanted 2 06-20-2006 09:58 AM
Timing belt / timing gear problems swapdohc General Tech and Maintenance 1 05-25-2004 11:43 AM
cam gear timing turbohatch Forced Induction 3 12-26-2003 09:09 AM
Cam Gear/ Timing Belt Install Accordturbo94 General Tech and Maintenance 0 05-23-2003 12:31 AM
