I'll be back...
Ride: 06 Mazda 5, 91 Civic DX
I saw the ad in the new super street. anyone know how these NGK one's are suppossed to be compared to the Denso Iridiums. I "heard" that Denso and NGK have some sort of partnership. i do not know if that is true in anyway but i never had luck in using denso plugs and i've always stuck to NGK. anyone think iridiums are worth the $?
Real Eyes Realize Real Lies |
Arent IRIDIUMS spark plugs to last longer and not as a more power plug??,correct me if im wrong.
1990 Civic Hb Si Engine B18C1:GS-R ,Eagle Rods,81.40mm Bore,Arias 9.1 Flattop Pistons,ARP Head Studs,Polished Crank,Engine Oil Cooler,92 Radiator with HI Flow Fan. Head B16:Skunk 2 Springs/Reatainers/Cam gears,Integra Type R Cams,3angle valve Job,Self Port & Polish,Type R Intake Manifold,AEM Fuel Rail,Mugen Thermostat,MSD 6A,MSD Distributor Cap,Msd 8.5mm Wires,Msd Coil,Apexi V-AFC,suspension Tokico Blue,Generic coil overs. And T3/T4 T.C, Set up Made by me. Future Upgrades:N1 Crack Pulley and TEIN SS coil Kit. My Ride: <a href=\'http://home.comcast.net/~arpee79/wsb/html/view.cgi-home.html-.html\' target=\'_blank\'>http://home.comcast.net/~arpee79/wsb/html/...home.html-.html</a> |
aftermarket ignition is absolutely worthless, unless you are detonating. if the stock stuff is still good, there is nothing to gain from different plugs, wires, caps, etc. eric aguliars 9 sec all motor civic runs a completely stock honda ignition system. if there was anything to gain from ignition, im sure he would be using it. he doesnt.
#4 | |
Ride: 93 del Sol Gas sipper
Collin Material Science and Engineering Michigan Technological University |
#5 | |
#6 |
Ride: RPS-13
to the leave your ignition systems alone. Honda does it right from the factory, Sumitumo wires, and NGK plugs. you really dont have a need to replace any of it unless it breaks or it gets really really old. just my .02 __________________
-Scott (O=O/RPS 13\O=O) ....finally SR'd http://www.nissanpacific.com --- for the nissans http://www.myspace.com/SkylineScottro -- My MySpace account durrrr. |
