No 4th gear after going to the track????
Old 09-13-2003, 01:33 PM   #1
Rep Power: 16 gocivicls is off the scale
Send a message via Yahoo to gocivicls
It will not go into fourth gear at all! Is it the syncro's?
Is it fixable? Or will it cost too much and it is just cheaper to get new tranny?
99 Gsr Tranny and it is my freinds. I think he missed a gear, oops!
<span style=\'color:red\'>14.2:1 CR LS with 405A's and working out the bugs</span>
<u>Fastest 60ft</u>
1.78
<u>Best ET on 1/8th</u>
8.42
<u>Fastest MPH</u>
82.23 mph
All Motor LS (B18B) <span style=\'color:green\'>Hasn't been tuned yet!</span>
gocivicls is offline   Reply With Quote
Old 09-13-2003, 01:35 PM   #2
Rep Power: 27 SleEPeR_CRX is off the scale
umm it would be cheaper to get a new 1, but if u dont really know what ur doing under there, id think ur best bet would be to buy a new tranny. either look for a gsr or b16 tranny, they will both do the same job, just whatever u can find a better price on.
Sleepers Are the Only way to Go.
1990 CRX Si
B18a(92) CAI/E, Gutted, ACT clutch/pressure plate/13lb flywheel, Crower 403 Cams, Titanium Valve springs &amp; Retainers, Blockguard, Head Milled 20 thou, 9.8:1 Compression, AEM cam gears.
1/4 = 14.73
60' = 2.48
trap = 95.03mph
Soon to get: Header, Slicks
Future 13 second all motor LS!
SleEPeR_CRX is offline   Reply With Quote
Old 09-13-2003, 08:09 PM   #3
88 C1V1C 53D4N DR1V3R
saturn_boy96's Avatar
Ride:  2006 Suzuki Aerio
Rep Power: 31 saturn_boy96 will become famous soon enough
Send a message via AIM to saturn_boy96 Send a message via MSN to saturn_boy96 myspace
damn... sorry to hear that man...
saturn_boy96 is offline   Reply With Quote
Old 09-13-2003, 11:51 PM   #4
Myself I think I could do it. I just want answers on the problem.
It will not go in 4th at all, so can you rebuild it or not. If so do you just buy the 4th gear, syncro's or both?
<u>Fastest 60ft</u>
1.78
8.42
<u>Fastest MPH</u>
82.23 mph
Old 09-13-2003, 11:55 PM   #5
Rep Power: 83 Havok is an unknown quantity at this point
Send a message via AIM to Havok
Put it on jacks, and check the shift linkage. It's going into all the other gears fine?
My skin is singed but it heals my heart
and with glowing pride I'll wear my scars.
I'm honored by your hatred!
She wanted love, I taste of blood.
She bit my lip and drank my warmth from years before.
Havok is offline   Reply With Quote
Old 09-14-2003, 12:01 AM   #6
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
check linkages, check/change fluid. What trans is it?
Collin
Material Science and Engineering
Michigan Technological University
Old 09-14-2003, 12:21 AM   #7
Rep Power: 27 NoJokE is off the scale
Send a message via AIM to NoJokE
GSR trans
T3T67
<a href=\"http://www.hondaswap.com/forums/index.php?showtopic=69573\" target=\"_blank\">Buy my MSD 6AL, Carsound Cat, VTEC Distributor!</a>
<a href=\"http://ipods.freepay.com/?r=11169222\" target=\"_blank\">Sign up for a Free Ipod!</a>
NoJokE is offline   Reply With Quote
Old 09-14-2003, 09:14 PM   #8
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Nope, sorry... if it's one of the synchro sets / gearsets, it's still cheaper to repair it if you do the labor yourself. I don't think you'd be able to buy a GSR transmission for under $300.
Old 09-14-2003, 10:42 PM   #9
Calesta, With out tearing it down to avoid down time on a dailey driver how can we tell if it is the gearsets or synchro's?
I guess if we get both gearsets and synchro's for 4th gear we could take back one or the other if not used.
I have never broke into a transmission, but I feel that I am very mech. inclined and I have been in, and rebuilt B series motors. Do you feel that I should attempt this project or is there a risk to make it worse?
<u>Fastest 60ft</u>
1.78
8.42
<u>Fastest MPH</u>
82.23 mph
Old 09-14-2003, 10:54 PM   #10
Calesta's Avatar
Ride:  2003 S2000
There's no good way to tell. Try your shift linkages like everyone said to make sure everything is ok on the outside of the transmission, and if you feel up to it- then drop it out and look inside.
If you're confident with tearing apart engines and rebuilding them, then you should have no problem rebuilding your transmission. Just make sure you know where everything is supposed to be when it goes back together, and replace only what you need to.
If you don't want any downtime... the fastest way to take care of it is to buy another known good transmission, then swap yours out and be done with it. I wouldn't want to order transmission parts without seeing what's going on inside first, because it could be any number of things causing your 4th gear not to engage... and transmission parts aren't usually something that you can just go to the dealer and get over the counter the same day.
Old 09-15-2003, 12:17 PM   #11
True! Well thanks for the info and wish me luck!
<u>Fastest 60ft</u>
1.78
8.42
<u>Fastest MPH</u>
82.23 mph
Old 09-15-2003, 02:29 PM   #12
Calesta's Avatar
Ride:  2003 S2000
Yes, good luck!
Honda Transmission specs pissedoffsol Reference Materials 3 10-12-2006 06:03 AM
took the ol' civic to the track today.... civicious Members' Lounge 44 02-17-2004 12:52 AM
B-series Tranny Speed VS. MPH pissedoffsol Reference Materials 0 01-06-2004 10:52 AM
went to the track tonight DjMcPhatty Racing and Driving Techniques 4 12-05-2003 05:48 PM
need help with gear sets oches HYBRID -> EG-EK / DC 0 11-03-2003 02:09 AM
