This nut is a bitch to get off..
Closed Thread
Old 12-19-2008, 01:13 AM   #76
Green on the scene.
MthaFuknGreen's Avatar
Ride:  Fuckin Prelude Si 2.1l 1990
MthaFuknGreen has a brilliant future
Send a message via AIM to MthaFuknGreen myspace
Originally Posted by AHHVTEC View Post
remember righty tighty lefty loosey lol
thats what ive been doing wrong!
lol
not.
im not sure if my drill would be much stronger, but ill try that too.
MthaFuknGreen is offline
Old 12-19-2008, 01:17 AM   #77
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
YBLEGAL has a brilliant future
myspace
i just know my dewalt drill owns a dremel hard core. found that out easily when trying to cut steel braided brake line.
maybe try an insanely fortified breaker bar and longer pipe as phyregod also said?
YBLEGAL is offline
Old 12-19-2008, 01:20 AM   #78
Green on the scene.
i dont know where a longer pipe is..
and i dont think i have enough to buy a new one.
but yeah, my dads dewalt is a fucking beast.
i just have a black and decker firestorm kit(with the sander and jigsaw and drill, im a wood worker..lol).
the only reason i even have that is because it was 20 bucks at goodwill.
Old 12-19-2008, 01:59 AM   #79
Ride:  06 RSX / 95 EG hatch/ 95 accord ex
95b18c1eg is on a distinguished road
look broham i don't know what your weight is but im 190 and my fat ass on a three foot bar couldn't get it! so i called my 265 buddy to jump on it. had to have been at 600 ft lbs.
95b18c1eg is offline
Old 12-19-2008, 02:06 AM   #80
Green on the scene.
lol.
i only weight like 180.
i been trying to squat the bar though, pushing it up instead of jumping on it.
cuz i can squat well over 300 lbs, and since the torque specs are only 135 ft lbs, i dont understand why its not moving.
fucking stubborn nuts.
about the heat, changing the properties..
i was only using a small propane torch, is that still enough to change the properties?
Old 12-19-2008, 02:34 AM   #81
YBLEGAL's Avatar
myspace
if your not making it red hot it's not changing the properties (it will be non magnetic when it's reached this temperature). but if your not making it red hot it's not doing anything to break the corrosion anyway.
YBLEGAL is offline
Old 12-19-2008, 02:44 AM   #82
reckl3ss's Avatar
Ride:  B16 92 Hatch /w GSR Front End Swap
reckl3ss is on a distinguished road
Did for me
reckl3ss is offline
Old 12-19-2008, 02:50 AM   #83
YBLEGAL's Avatar
myspace
Ok well from what I've read, and my experience with the torx bolts that hold the rear disk spindle to the trailing arm it mattered. This one bolt in particular didn't want to come out. The surrounding surface being hot didn't matter, only when I got it red hot.
YBLEGAL is offline
Old 12-19-2008, 09:36 AM   #84
stevennn09's Avatar
Ride:  94 civic Ex
stevennn09 will become famous soon enoughstevennn09 will become famous soon enough
Send a message via AIM to stevennn09 myspace
than you're gunna want to use a pry bar. wedge it in between the axle hub and the transmission. have someone putting a small amount of force on the axle and the wheel hub to stop the cv from seperating. than slowly work the axle out of the trans. it would be easiest to do with your strut//spring being removed. than have the person pull on the hub, towards them, while they're holding with the other hand the axle to keep it in the cv joint itslef not to hyper extend the axle, because if you do you will mostliely never get the axle back together wihtout it being a pain in tha ass. you should also be pushing towards them to keep pressure on the axle and in moments you should have a free axle//spindle assembly. set it somewhere where it's not gunna get kicked around or anything. i'd put cardboard underneath your rotor as well. btw with the caliper since you have to remove it make sure that you have something holding it up and it's not just dangling there.
i got that pic from hondtech incase it's anyones car or anything.
heavens not a place that you go when you die it's that moment in life when you actually feel alive, so live for the moment now.
stevennn09 is offline
Old 12-19-2008, 09:52 AM   #85
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
phyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
OK. Erase from your mind everything you think you know and all of the options that you have explored.
There is a proper way to do this, and there is a proper tool for the job. Using this method will not damage your car in any way whatsoever and is actually recommended by Honda themselves.
Its called a breaker bar. Go borrow one, Check out auto zone's loan-a-tool program. Hit the local pawn shops. I know you said you don't have any money, but you should be able to pick up a nice one for $20-40. You should be able to come up with $40 somehow..
Just go do it, before you damage a $60 axle and end up having to buy a breaker bar later in life for something else anyway. Its just one of those tools you should have around.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
phyregod is offline
Old 12-19-2008, 09:53 AM   #86
nootrac22's Avatar
Ride:  daily driver working on 92 prelude 4ws
nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
Send a message via Yahoo to nootrac22 Send a message via Skype™ to nootrac22
is the axle still good? do you plan on putting the same axle back in the car when you're done?
nootrac22 is offline
Old 12-19-2008, 10:33 AM   #87
has a CRX Si
cjvictoria's Avatar
Ride:  1990 CRX si
cjvictoria has a reputation beyond reputecjvictoria has a reputation beyond repute
Send a message via Yahoo to cjvictoria
shyte i have a black and decker grinder that came with a cutting wheel, got that shit for thirty bucks at wal mart.. go check out wal mart!
cjvictoria is offline
Old 12-19-2008, 02:42 PM   #88
Green on the scene.
have no way to come up with money until the end of the month.
yes
dont have 30 bucks or a ride to walmart.
lol
and the point of the heat isnt to remove the corrosion on the nut, its to draw the p.b. penetrating fluid into the nut, which will remove the corrosion.
Old 12-19-2008, 05:01 PM   #89
YBLEGAL's Avatar
myspace
Does that work??? Heat will draw the PB in?
Never heard that. Did read and was told heating breaks the corrosion with the expansion of the metal
YBLEGAL is offline
Old 12-19-2008, 06:15 PM   #90
!!YTINASNI
phyregod's Avatar
myspace
Actually, the point of the heat is to expand the metal of the nut, thereby loosening it.
phyregod is offline
Old 12-19-2008, 07:04 PM   #91
|Chaz|'s Avatar
Ride:  92' EG Sedan
|Chaz| has a reputation beyond repute
|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute|Chaz| has a reputation beyond repute
Send a message via AIM to |Chaz| Send a message via MSN to |Chaz| Send a message via Yahoo to |Chaz|
Don't you have a jack? Does the handle come off of the jack? If it does put the end of the jack handle over the handle of the socket wrench. That'll be more than enough leverage...
|Chaz| is offline
Old 12-19-2008, 07:09 PM   #92
Green on the scene.
chaz, read a little more of the thread..
ive answered this question a few times already.
Old 12-19-2008, 07:12 PM   #93
|Chaz|'s Avatar
Ride:  92' EG Sedan
Sorry, I don't have the patience to read through 90 posts about how you can't figure out how to get a nut off. You're just lucky I wasn't feeling like a smartass and post a link to some porn.
|Chaz| is offline
Old 12-19-2008, 07:14 PM   #94
has a CRX Si
cjvictoria's Avatar
Ride:  1990 CRX si
how is that a smartass thing to do?? oh wait i get it, get a nut off lol
Old 12-19-2008, 07:20 PM   #95
Green on the scene.
well, apparently you cant figure out how to get it off either.
cuz that didnt work.
Old 12-19-2008, 07:38 PM   #96
|Chaz|'s Avatar
Ride:  92' EG Sedan
Actually if it was me I'd already have it off. I would have gone and bought the tool necessary to get the bolt off already...
|Chaz| is offline
Old 12-19-2008, 07:39 PM   #97
Green on the scene.
well come down and get it off for me then..
lol
Old 12-19-2008, 09:00 PM   #98
is lol'ing @ you
newb's Avatar
Ride:  '98 Z28
newb has a reputation beyond reputenewb has a reputation beyond repute
Send a message via AIM to newb myspace
I still don't understand how this is soo hard to do. Ok, you don't have the money for tools. You don't have neighbors? You can't borrow tools? Do you have any big box end wrenchs? If so, put the biggest box end you have over the end of your ratchet. It'll give you leverage, I do it quite often.
newb is offline
Old 12-19-2008, 10:37 PM   #99
YBLEGAL's Avatar
myspace
if you dont have tools, dont begin the job. now ur stuck, scrape up money for a strong breaker bar and a pipe.
YBLEGAL is offline
Old 12-19-2008, 10:48 PM   #100
|Chaz|'s Avatar
Ride:  92' EG Sedan
It's MthaFuknGreen, what do you expect?
|Chaz| is offline
Closed Thread
this bitch hit my car TurboMirage NorthEast 23 12-17-2008 03:08 PM
son of a bitch....... 92civicb18b1 Members' Lounge 67 06-16-2005 05:27 PM
Bitch bitch bitch. Loco Honkey Members' Lounge 18 07-26-2004 11:12 AM
bitch of the day swanny Members' Lounge 11 04-02-2004 07:24 PM
