Is 10w40 to much? I did an oil change and didint really see i grabbed 10w40, am i strait?
97 Acura integra GS-R AEM cold air intake Apex-i N1 cat back Dc header best 1/4 15.4 --------------------------- |
yeah, it is just a little thicker or an oil. I have a friend who used to burn oil like crazy when he gave it, so he switched to 10w40 and hes run it ever since, and the oil burning problem has been reduced. Just don't mix. use all 10w40 or all 5w30. it should be fine
DArin |
I had to mix last night cause i guess i didnt put enough in and it was like 12 midnight and all they had was 10w30
And what i put in my car was 20w50, i was mistaken befor, so now were clear. My problem is i pput 20w50 in my car and then mixed one quart of 10w30. First question A. was the 20w50 a bad fuck up? B. Was mixing the the one quart of 10w30 super bad? __________________
#5 |
I use 10w 40 in the D15 and if I use 10w 30 I burn more than a quart every 3000 miles. In the B16 I am not sure what I will use probably something super heavy like swepco.
2004 Toyota Tacoma 3.4L V6 TRD Package 4WD ---------------------- |
#7 |
the answer it it is better to NOT to mix viscosities (sp?) but your one qt of lighter weight when you used 20W50 primarily shouldn't cause MAJOR problems.
Would it be better to drain and start over, yes. Will your engine fall apart between now and your next scheduled oil change? Well, how often do you change the oil anyway? edit: 20W50 isn't bad if your motor has a lot of miles and is smoking due to worn rings. It'll smoke less now. Otherwise, it depends on where you live. 10W40 should be good for the summer. |
#8 |
Would someone please read there owners manual. 5W30 is reccomended unless you live in an area that frequently experiences over 70 degree weather! 20W50 in a honda?
Also the thicker oil will rob you of fuel economy as well as horsepower!__________________
Do your own work that way you know its done right! (The following should only be ahered to if you are mechanically inclined) |
#9 |
dude, chill. Just because Honda says that you should use 5w30 doesn't mean that its the only thing you CAN use. We all know that 5w30 is what is recomended, but it really doesn't matter. Is not going to destroy his engine or anything.
No tech questions through PM please! B16 CRX....you will be missed
#10 | |
I really don't think I need to chill. I'm just tryin to pass on some common knowledge thats been over shadowed by opinions and myth. Then again, I'm pretty sure your smarter then the engineer who designed and built his engine huh? Have a nice day B) __________________
#11 | |
Blah blah blah....
I use 10w30, it seems to work well enough. 5w30, doesn't the back of those bottles of oil say that it is is for low emissions vehicles? I was told that the 5w stuff will break down under high operating temps, like in say...racing? So I would use anything under a 10w oil in my car unless I was just driving miss daisy. 20w50 isn't gonna hurt your motor, it is just a more viscous fluid the the motor has to pump through its veins and squeegee off its cylinder walls. A little power loss from that, but your motor should be fine. Turbo cars that I have driven recommended the 20w stuff in the motors because of the oil being a method of cooling the turbo, and the heavier oil could absorb more heat. Should be fine bro, just change the oil a little earlier this time around.
#12 | |
I really don't think I need to chill. I'm just tryin to pass on some common knowledge thats been over shadowed by opinions and myth. Then again, I'm pretty sure your smarter then the engineer who designed and built his engine huh? Have a nice day B) [/b][/quote] Well, honda engines wern't origninally made for racing. So I guess you'd better not do that, because that is also not condoned by the manufacturer. OH yeah, and you'd better not do engine swaps. Thats bad for you car too! I know that using drasticly more viscous oil is bad, but using 10w30 isn't going to kill a honda engine. You're more likely to damage it by pulling ricer revlimiter bounces on a daily basis. __________________
#14 | |
You really like those ricer comments don't ya? ![]() __________________
