This is a discussion on oil leaking in the General Tech and Maintenance forum
hey guys, it seems that my oil is leaking from my drain bolt on my oil pan. should i just get a new bolt and washer? i dont think its stripped. any ideas?...
| | #1 |
| hey guys, it seems that my oil is leaking from my drain bolt on my oil pan. should i just get a new bolt and washer? i dont think its stripped. any ideas? |
| | #2 |
| Yah you defenatly need a new oil bolt. I believe the washer comes with it!! |
| | #3 |
| sweet ill pic one up next weekend. it doesnt leak bad, but whenever im under it its wet with oil, not draining out though |
| | #4 |
| Yah you have a minor leak! It most likely is coming trough the thread of the bolt1 |
| | #5 |
| Have you replaced that crush washer? I find that if I do not replace that washer with every oil change mine leaks a little as well. |
| | #6 |
| haha, ive never replaced it. i guess i should do that, where do i get the bolts and washers from? i would prefer not going to the dealer, since my dealers like to rape me on price and the dealers are very far away. advanced auto is just easier. |
| | #7 |
| www.hondaautomotiveparts.com They can get you all that you need. They claim to be able to get the Toyo-Roki oil filters. (Part number 15400-PR3-014 ) |
| | #8 |
| have u tried just to tightin the bolt some more |
| | #9 |
| no i never thought of that, lol, jk. i tightened it wit a 18" breaker bar (only because i used to get it off, and i didnt feel like getting another wrench) beleive me, if its any tighter i will strip it. |
| | #10 | |
| Quote:
| | #11 |
| Don't tighten it any more unless you want to have to start running an oversized drain plug. |
| | #12 |
| Toyo-Roki makes the oil filters that Honda uses in Japan. I don't think you will find the right crush washer anywhere but a Honda dealer. SO you just get to choose local or internet. |
| | #13 | |
| Quote:
![]() So if your oil leak is not because of a lack of a fresh crush washer, then you probably have to go to an oversized drainplug. | |
| | #14 | ||||
| Quote:
__________________ HEAT '91 CRX si '10 WRX I DO NOT answer tech questions via PM. Use the forums!!! Quote:
| | #15 | |
| Quote:
| | #16 | |
| Quote:
Do you? I have never replaced mine and I have never had an oil leak! | |
| | #17 | |||
| Quote:
i have not replaced mine for 3 oil changes, but i normally change it every time. shit, if you buy your filter from the dealer they usually give you a new washer without even asking, lol | |||
| | #18 |
| Well I guess you learn something every day! |
Similar Threads | ||||
| turbo leaking | b16rex | Forced Induction | 8 | 07-26-2004 04:16 PM |
| Fuel Is Leaking From The Driver's Side | MarkJimenez99 | General Tech and Maintenance | 5 | 06-03-2003 12:45 PM |
| Windshield Leaking | pjhaddock | General Tech and Maintenance | 0 | 06-03-2003 10:51 AM |
| Coolant Leaking | importimage | HYBRID -> EG-EK / DC | 2 | 03-28-2003 04:34 AM |
