Over bore my pistons
Old 12-02-2005, 04:33 PM   #1
Rep Power: 12 mozzandherb is off the scale
I'm looking into buying some Mahle pistons 9.1 with 87mm bore for my H22 (that's what the stock bore is), but I've been reading some other threads and people are buying these pistons with a .25mm over bore just to be safe in case there cylinders wall are a little messed up. Now I bought this motor used and I haven't seen the cylinder walls and I no expert when it comes to this, but I'm wondering IF I buy these pistons would it be wise to oreder the over bore 87.25mm or should I stick with the 87mm? Or is there a way to tell what size I should be using? I guess there is right, but that would involve measuring the cylinder walls. What woudl you guys suggest 87 or 87.25 to be safe?
mozzandherb is offline   Reply With Quote
Old 12-02-2005, 04:34 PM   #2
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
i would keep it 87 unless you NEED to over bore..... the machine shop knows....
http://pandora.com/
Old 12-02-2005, 05:22 PM   #3
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
Cant overbore an H22
Anime Informant
reikoshea is offline   Reply With Quote
Old 12-02-2005, 05:33 PM   #4
<div class='quotetop'>QUOTE(reikoshea @ Dec 2 2005, 06:22 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I don't mean the FRM sleeves I'm just thinking about the pistons.
Old 12-02-2005, 07:28 PM   #5
HS Troll...And Mod
reikoshea's Avatar
myspace
i know what you meant. my comment was directed to formby.
Anime Informant
Old 12-03-2005, 03:45 AM   #6
<div class='quotetop'>QUOTE(reikoshea @ Dec 2 2005, 08:28 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]So what do you think would be the best thing to do? Get it measured? And man I don't know what you think but fuck homemadeturbo site, all they do is bash eachother...no help at all.
Old 12-03-2005, 04:47 AM   #7
HS Troll...And Mod
reikoshea's Avatar
myspace
yeah...thats what it seems like to me too.
Yeah, get the cylinders checked. you shouldnt have much of a problem staying with 87 though.
Anime Informant
Old 12-03-2005, 03:08 PM   #8
<div class='quotetop'>QUOTE(reikoshea @ Dec 3 2005, 05:47 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
If I do go with a turbo is there anything I might have to worry about with my tranny?
Old 12-05-2005, 02:24 AM   #9
HS Troll...And Mod
reikoshea's Avatar
myspace
just your clutch...youll have to get one that will support your new horsepower or your engine will probably just rev out of gear.
Anime Informant
