overheating an i aint even runnin it...
Members have access to more features and see fewer ads! It's free, what are you waiting for?
Old 07-26-2008, 09:13 PM   #1
Ride:  95 eg coupe
Rep Power: 0 terry is on a distinguished road
myspace
Exclamation overheating an i aint even runnin it...
95 eg coupe
d15b
an other parts
okay so lets say im driving an the car jus starts overheating at firts it was thorowing white smoke...ani thought it was the oil so i pput in oil buh now its like if somethins burnin all of a sudden an i stop to put water on it an the meter goes down an its like nothin an 5 mins later the meter starts goin up..
an the bottle that hold the water for the radiator is full anits not leakin...any suggestion??
terry is offline   Reply With Quote
Old 07-26-2008, 09:29 PM   #2
Rep Power: 1 Wikidconsepshnz is on a distinguished road
check the thermostat may need replaced but if its got white smoke coming out the exhaust it sounds like the head gasket is blown.
Wikidconsepshnz is offline   Reply With Quote
Old 07-26-2008, 09:33 PM   #3
Ride:  95 eg coupe
myspace
mhmm i was hoping it had nothin to do wit that..>=(
Old 07-26-2008, 09:42 PM   #4
90_EF_Hatch's Avatar
Ride:  90 DX civic hatch
Rep Power: 32 90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of
myspace
Originally Posted by terry View Post
mhmm if its the head gasket wat do i have to change...
an wats the head gasket??lol
if its the head gasket you must change ... wait for it ...
THE HEAD GASKET!! its a little gasket between the head and the block that keeps oil and coolant from mixing together.
I used to be a noob not to long ago but stick around and you will learn alot
But back to the problem ...as Wikid stated you should probably change your thermostat too because i had the EXACT same problem you do and the new thermostat cleared it up
The thermostat is located at the end of the bottom radiator hose where it meets with the block. Its a fairly simple procedure, you just loosen the clamp, pull off the hose, and the thermostat should be right there. there are like 3 bolts you have to pull of but that's simple as well. At this point you just remove it and put in the new one. put the bolts back on, clamp the hose back and Voila!!! your car should be A ok
and at some point if your car keeps smoking you might want to check out the head gasket
keep us updated with questions
:edit:
too answer your next question if your head gasket is blown your oil and coolant could mix together wich is not good for your engine. A blown head gasket can lead to a blown engine.
"Examine what is said, not him who speaks. "
Originally Posted by Celerity View Post
I've had a zombie plan in place for over a decade, and my friends are in on it.
It also works for Muslims / Sharia law and Liberal take overs.
Originally Posted by UNDR8D View Post
Ya. Chicks also dig guys that beat them and don't have jobs...but, let's not turn this into one of those.
90_EF_Hatch is offline   Reply With Quote
Old 07-27-2008, 07:48 PM   #5
Ride:  95 eg coupe
myspace
aright thanks..=)
Old 07-27-2008, 08:32 PM   #6
Bkkfarang's Avatar
Ride:  95eg extreme single cam / 06jazz hks turbo soon/
Rep Power: 7 Bkkfarang has a spectacular aura aboutBkkfarang has a spectacular aura aboutBkkfarang has a spectacular aura about
sounds like a bad thermostat and possibly a bad head gasket
Bkkfarang is offline   Reply With Quote
Old 07-27-2008, 08:42 PM   #7
D16Civic's Avatar
Ride:  95 EX Coupe / 07 Saturn Aura for the wife
Rep Power: 7 D16Civic has a spectacular aura aboutD16Civic has a spectacular aura aboutD16Civic has a spectacular aura about
Try a little puncuation, and at least attempt to spell a few words correctly. My head hurts when I have to read posts like that.
Squeeze a boob, save a life
D16Civic is offline   Reply With Quote
Old 07-27-2008, 08:52 PM   #8
Bkkfarang's Avatar
D16, if you’re going to tell people to spell correctly you should not have misspelled your self.
Punctuation
Old 07-28-2008, 07:19 PM   #9
D16Civic's Avatar
Punctuation
Nice catch. I guess I have no room to talk. Just typing too fast and missed the "t".
Old 07-29-2008, 04:58 PM   #10
Ride:  95 eg coupe
myspace
alright alright..thanks but either way it wasnt even the thermostat it was one of the hoses that goes to the heating system it was ripped an the radiator water was comin out through there thanks either way..
Forum Jump
Improperly Runnin B16 frog37+ General Tech and Maintenance 1 08-08-2006 06:22 PM
That aint yogurt! TurboMirage Members' Lounge 3 01-25-2006 11:46 PM
say it aint so mrnice1058 HYBRID -> EG-EK / DC 3 07-14-2004 09:23 PM
ZC runnin rich? CompFX HYBRID -> ED-EF / DA 10 06-05-2004 03:48 PM
what manifold are you runnin? breed Forced Induction 13 05-06-2004 11:29 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
