This is a discussion on Power Steering Tight in the General Tech and Maintenance forum
i have a 93 SI and when the car is cold (in the morning). The steering is really really tight.... When the car is warmed up a bit.. the steering gives a little bit more movement. I have already changed the rack and there was ...
| | #1 |
| i have a 93 SI and when the car is cold (in the morning). The steering is really really tight.... When the car is warmed up a bit.. the steering gives a little bit more movement. I have already changed the rack and there was no change in the steering... What else could cause this problem... could something be missing or could a line be crimped up somewhere... There is no leaks, the pump and belt work fine... NE help would be nice!!!!! |
| | #2 |
| You could have a crimped or blocked line. The other possibility could be (and im not a hundred % familiar with the setup on that car) that the u-joints int the shaft could be seized. |
| | #3 |
| Everything is still stock... |
| | #4 |
| are you sure the belt is working fine? it may be a slipping belt. check the tension on it. make sure the pump is mounted correctly and tightly. |
Similar Threads | ||||
| Power Steering issue | AmonDin | HYBRID -> BA-BB /CA-CD | 5 | 05-01-2004 07:15 PM |
| Power Steering Removal Kit? | turbo99 | General Tech and Maintenance | 14 | 02-25-2004 01:25 AM |
| a/c and power steering | civicious | General Tech and Maintenance | 6 | 07-08-2003 01:30 AM |
| Power Steering Tight | Jazzy19 | General Tech and Maintenance | 5 | 03-24-2003 01:56 AM |
| Civic Cx Power Steering Question | vietec | HYBRID -> EG-EK / DC | 5 | 01-16-2003 07:42 AM |
