Problem with a prelude
Old 05-02-2004, 07:52 PM   #1
Honda Power
hondaman74's Avatar
Rep Power: 12 hondaman74 is off the scale
Send a message via AIM to hondaman74 Send a message via Yahoo to hondaman74
Ok here is my problem the car died once on the road then it wouldnt start back I waited about 5 mins and it cranked back up. I figured a loose battery I tightend up the ground then was fine for 3 days well my sweety drive the car to work one day it dies.It doesnt start back well i went over everything that I could think of it would replaced the ground wire no fix replaced the ignition coil no go heck I dont even get spark from the plug wires when the motor is being cranked getting gas so fuel pump works fine even check to see if timing belt was broke nope that fine as well I tryed jumping it off it ran turn it off cranked it back up will it was being jumped it ran joy right wrong thinking it was a dead in battery well I replaced battery it cranked up right after I hooked up battery pk a few hours went by thinking it was fixed when out to drive it bam nothing motor turns over but no go can anyone help me in this matter please
Honda we make it simple rember that slogan.
hondaman74 is offline   Reply With Quote
Old 05-04-2004, 01:04 AM   #2
Rep Power: 13 preludude is off the scale
Dude, its a simple problem. I was in your situation about 2 years ago when I first got my prelude.
its in your distributor, thats where the ign. module is located. Without that, your car will crank forever and not start. You got the coil, but you need the ign. module as well to get the engine to turnover.
What year prelude? If you have 92-96, its definitely the distributor/ign module.
preludude is offline   Reply With Quote
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
94 accord lx to 94 prelude dist. problem 1994h22accord HYBRID -> BA-BB /CA-CD 2 07-02-2004 12:05 AM
Prelude 1997 Heat problem... ovcrash General Tech and Maintenance 2 03-12-2004 11:45 AM
Decoding VIN Numbers pissedoffsol General Tech Articles 0 01-11-2004 08:48 PM
All This Reference Material, And No Cel Code Chart Slo86GT Members' Lounge 5 06-13-2003 10:31 AM
