Prothane Motor Mount Inserts
Old 02-04-2003, 11:29 AM   #1
Rep Power: 0 ayaran is off the scale
Quick question. Has anyone used these on their civic and if so how long do they take to install. I was told anywhere from a few minutes to a few hours. Can I install them easily enough myself with basic tools? Any info would be greatly appreciated.
ayaran is offline   Reply With Quote
Old 02-04-2003, 11:49 AM   #2
Rep Power: 14 sabi670 is off the scale
I had a set of mount inserts put into my 96 hatch. You should have jackstands, basic 1/2" socket set (10-21mm) [3/8" drive might not be strong enough to remove some bolts, or you might be able to get away with the 3/8" if you have a 1/2" breaker bar], floor jack. an impact wrench/socket set will make things much easier of course.
i bought the inserts because i heard that it helps reduce wheel-hop, which should translate into better take-offs. My experience is that , yes , it helped reduce wheel-hop, but doesn't totally eliminate it; wheel-hop is still present when dropping the clutch at high rpm (5k +) [or maybe i just need to upgrade my suspension]. one side effect to consider: noticeablly (?) more buzzing/vibration from the engine. Make sure you have a very good cd deck with shock protection.
Overall, I am pleased with the inserts. I like the feel of the engine in my hands, take offs are better, and less hop means longer life for the halfshafts/axles.
<span style=\'font-size:8pt;line-height:100%\'><span style=\'color:red\'><span style=\'font-family:Arial\'>F'em ricers!!</span></span></span>
96 DX Hatch
y8 mini me
pnp, crower cam, fidanza flywheel, ACT Clutch, MSD 6AL, 8.5 wires, GHETTO-FAB broken muffler!! 17sec. club!!
sabi670 is offline   Reply With Quote
Old 02-04-2003, 11:56 AM   #3
Sorry, forgot to say that I had a friend help me out, we did it in about 4 hrs. But we're not pro mechanics. It wasn't too difficult: on scale of 1-10 (1=oil change, 5=valve adjustment, 10=tranny work) id put it at about a 6. Like I said though, I'm not a mechanic by trade, you might find it easier.
96 DX Hatch
y8 mini me
Old 02-05-2003, 06:29 PM   #4
Rep Power: 19 ekPhred is off the scale
Send a message via MSN to ekPhred
yea, exactly what sabi said. I had the mounts on my 99 si and i loved it. If you don't mind the vibration that you will get, especially in the steering wheel. The car pulls more because the engine is no longer moving when it is under high revs because of the mounts. The mounts are worth it definately. took around 2-3 hours to do, peace!
For Sale thread... Buy now BITCHES!
<a href=\'http://www.hondaswap.com/forums/index.php?act=ST&f=5&t=36885\' target=\'_blank\'>http://www.hondaswap.com/forums/index.php?act=ST&f=5&t=36885</a>
ekPhred is offline   Reply With Quote
Old 02-05-2003, 06:37 PM   #5
Rep Power: 20 TRuggiero_ is off the scale
I've got some pictures of when I installed some Energy Suspension motor mounts if you want. email me TRuggiero_@hotmail.com
This is my civic. There are many like it, but this one is mine.
My civic, without me, is useless. Without my civic, I am useless.
Think your Cool? Take the <a href=\'http://www.sailinganarchy.com/general/2002/cool_test.htm\' target=\'_blank\'>test!</a>
TRuggiero_ is offline   Reply With Quote
Old 02-05-2003, 06:41 PM   #6
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
just link them [ IMG] www.pics address here [/IMG ] remove the spaces and you have a pic. Don't have it uploaded to the internet, no problem, Go to the gallery is now open and follow the directions.
Collin
Material Science and Engineering
Michigan Technological University
Old 02-06-2003, 11:16 AM   #7
Rep Power: 14 thuy is off the scale
I installed these in my 91 CRX. I was very impressed. It took me about 2 hours. All you need to do is support your engine from the bottom, and pull one mount at a time off. Insert the mounts. Put them back on. No special tools required.
91 CRX SI
thuy is offline   Reply With Quote
think ima get me some Prothane motor mount inserts civicious General Tech and Maintenance 5 02-21-2004 11:57 AM
Prothane Bushings Installed dwn2low Wheels / Suspension / Tires / Brakes 8 08-18-2003 12:02 AM
f/s Prothane bushings dwn2low Parts: For Sale/Trade/Wanted 1 08-10-2003 12:17 PM
Urethayne Moutn Inserts Baker General Tech and Maintenance 3 01-29-2003 02:24 AM
