Ride: 2007 Camry / 2005 Acura MDX
I'm removing my cold air intake..and I tossed out the OEM intake system I had..
What all do I need to have to put it back to stock? here is one on ebay i found What else would I need? __________________
2007 Camry XE 2005 Acura MDX Touring Edition |
Ride: 2008 Fit Sport
You will need the three mounting screws for the air box. if you want to bring it back to completly stock there is another lower section that goes behind the corner of the bumper.
2008 NHBP Fit Sport: HFP muffler, Mishimoto carbon fiber intake, Eibach Pro-Kit, Resonant Engineering 12" SE sub with a Premier PRS-D1100M |
know what the section is called? Is there a place online I can just order everything as a kit?
TTIWWOP
Ride: 90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
you'd be better off going to a junkyard...
I'll blow a hole in your face then go inside and sleep like a baby. |
#5 |
<div class='quotetop'>QUOTE(reckedracing @ Oct 10 2005, 03:48 PM) Quoted post</div><div class='quotemain'>
you'd be better off going to a junkyard... [/b][/quote] thats what I was thinking __________________
#6 |
The other section is comprised of a resonator and two sections of plastic pipe. check this out: http://www.hondapartssource.com/luteriley/.../13sr30_d01.gif
#7 |
<div class='quotetop'>QUOTE(92CHB @ Oct 10 2005, 04:49 PM) Quoted post</div><div class='quotemain'>
The other section is comprised of a resonator and two sections of plastic pipe. check this out: http://www.hondapartssource.com/luteriley/.../13sr30_d01.gif [/b][/quote] sweet thanks man __________________
#8 |
Führer Mod
try this.....he has the whole car so if you need anything
http://www.hondaswap.com/forums/index.php?...07&#entry596507 |
#9 |
You're wasting time and money putting the lower resonator section back on. It does nothing for or against the engine. It does nothing to make the intake quieter, it doesn't help pull in any cold air (it does the opposite actually), and serves no purpose other than filler for the fenderwell.
Take this as gospel coming from a guy who just removed his and noticed absolutely no change whatsoever. I removed it to install my Korbach frame locks, because you can't install them on an EG with this black box in the way, and left it off just to see if there was a difference. There is none. Skip it dude. __________________
1993 Civic DX Hatch B16A SiR-II --SOLD! 1988 Supra Turbo automatic FOR SALE $2000 needs trans repair, power steering repair, a few leaks, Clean Body, Alpine, leather interior in decent shape, JDM motor rebuilt with HKS metal head gasket and ARP head bolts. 1996 Toyota Celica GT (daily driver) |
#10 |
2265787829
Ride: Refer to my name, dumbass.
<div class='quotetop'>QUOTE(confusatron @ Oct 15 2005, 12:50 AM) Quoted post</div><div class='quotemain'>
You're wasting time and money putting the lower resonator section back on. It does nothing for or against the engine. It does nothing to make the intake quieter, it doesn't help pull in any cold air (it does the opposite actually), and serves no purpose other than filler for the fenderwell. Take this as gospel coming from a guy who just removed his and noticed absolutely no change whatsoever. I removed it to install my Korbach frame locks, because you can't install them on an EG with this black box in the way, and left it off just to see if there was a difference. There is none. Skip it dude. [/b][/quote] So you swapped the engine and then proceeded later on to take out the resonator? hmm... why didn't you rip it out before stuffing it into the fenderwell? Anyway, the notice of sound is from putting a CAI in, not necessarily from taking the resonator off. However, when I removed the resonator from my Escort I did notice a difference in sound, and I could hear my secondaries opening. Then I put a SRI intake on it and it was even louder. So yes, you WILL hear a difference. But that's not the point, the point is he wants to return it to stock. The resonator is stock. JDM... just a question, why are you doing that anyway? (not that it matters either way) |
#11 |
<div class='quotetop'>QUOTE(2000Si @ Oct 15 2005, 12:54 AM) Quoted post</div><div class='quotemain'>
<div class='quotetop'>QUOTE(confusatron @ Oct 15 2005, 12:50 AM) Quoted post</div><div class='quotemain'> You're wasting time and money putting the lower resonator section back on. It does nothing for or against the engine. It does nothing to make the intake quieter, it doesn't help pull in any cold air (it does the opposite actually), and serves no purpose other than filler for the fenderwell. Take this as gospel coming from a guy who just removed his and noticed absolutely no change whatsoever. I removed it to install my Korbach frame locks, because you can't install them on an EG with this black box in the way, and left it off just to see if there was a difference. There is none. Skip it dude. [/b][/quote] So you swapped the engine and then proceeded later on to take out the resonator? hmm... why didn't you rip it out before stuffing it into the fenderwell? Anyway, the notice of sound is from putting a CAI in, not necessarily from taking the resonator off. However, when I removed the resonator from my Escort I did notice a difference in sound, and I could hear my secondaries opening. Then I put a SRI intake on it and it was even louder. So yes, you WILL hear a difference. But that's not the point, the point is he wants to return it to stock. The resonator is stock. JDM... just a question, why are you doing that anyway? (not that it matters either way) [/b][/quote] I never took it out because I haven't put an aftermarket or custom CAI on yet. I've been busy trying to get the ride set to where I want it with all new suspension and tie bars, and the frame locks. I do have a magnaflow catback with a magnaflow hiflow cat converter, but that's the extent of my performance mods at this point. It's fast enough atm for me to focus on the more immediate problem of my ride quality sucking ass. I've got more rattles than I can stand right now, and I'm trying to iron them all out before I go insane. Later on I'll put a better intake on it, but for now it's fine the way it is. __________________
