Rattle?
Old 03-05-2004, 02:04 PM   #1
Rep Power: 0 streetz95GSR is off the scale
I've got a 95 GSR Integra, and in every gear from bout 3200 RPM's too 3800RPM's it makes this rattling noise, and it's only in between those RPM's, I think it might be the heat shield over the cat, but im not sure, anyone have any input..?
streetz95GSR is offline   Reply With Quote
Old 03-05-2004, 03:10 PM   #2
my avatar is better.
Rep Power: 52 YouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to behold
Send a message via AIM to YouKnowWhoIBee
Where is the noise coming from? Like in what area? My buddy had the same problem. He heard a rattleing(sp) noise come from his engine bay. we thought it was the heatsheild but it wasnt. It turns out he was using the lowest octane gas and once he started to use higher octane gas it went away. When you use a lower octane gas some engines have a slight rattling noise. The rattleing(sp) noise is the engine burning off more octane then it has. But it might not be your problem. Sorry if it is hard to understand but it is hard to put into words. It may not help but thats my .02
YouKnowWhoIBee is offline   Reply With Quote
Old 03-05-2004, 03:45 PM   #3
check the heat sheilds under your car. Those rattled on my integra then I took em off, every single one and it went away.
Also could it be loose change... ha ha haa J/P
90 Integra Sedan
B20V 225 / 153
Old 03-05-2004, 07:20 PM   #4
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 546 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
sounds like heatsheilds
МОΛΏΝ ΛΑΒΈ
Old 03-06-2004, 02:14 AM   #5
well i only use 94oc, so it can't be that...ima take off the heat shield over the cat this sunday and see what i get, thanx for the input guys
Old 03-06-2004, 02:19 AM   #6
dohch22a4's Avatar
Rep Power: 31 dohch22a4 is off the scale
Send a message via AIM to dohch22a4
That's called knocking. It's caused by the gas not having high enough octane in order to resist preignition. If he's using 94 octane, it sure as shit isn't knocking. Probably just heatshields. Tighten them down or take them off.
"Conventional wisdom would have one believe that it is insane to resist this, the mightiest of empires... but what history really shows is that today's empire is tomorrow's ashes, that nothing lasts forever, and that to not resist is to acquiesce in your own oppression. The greatest form of sanity that anyone can exercise is to resist that force that is trying to repress, oppress and fight the human spirit."
-Mumia Abu-Jamal
dohch22a4 is offline   Reply With Quote
can i clear over the top of rattle can spray paint ssl2k Body / Exterior / Interior / Cosmetics 2 07-04-2004 04:08 AM
Valve Rattle Engwar General Tech and Maintenance 0 04-16-2004 12:55 AM
Shift Knob rattle? Harms Way General Tech and Maintenance 13 04-01-2004 03:29 PM
Rattle At 3500 Rpms digital_toad General Tech and Maintenance 4 06-12-2003 12:26 AM
