Facebook Twitter
Rear disc brake conversion for 96-00 civic
This is a discussion on Rear disc brake conversion for 96-00 civic in the General Tech and Maintenance forum
Has anyone done a disc brake conversion from drums with the si brake componets on 96-00 civics? I know I need to get the rotors, calipers, caliper mounting brackets, hub/bearing assembley, and splash guards for each rotor. but do i need to change the hydraulic ...
Closed Thread
Old 11-30-2005, 08:53 PM   #1
Has anyone done a disc brake conversion from drums with the si brake componets on 96-00 civics? I know I need to get the rotors, calipers, caliper mounting brackets, hub/bearing assembley, and splash guards for each rotor. but do i need to change the hydraulic lines to make it compatible with the calipers? also, is the e-brake cable compatible with the si rear calipers as well? if anyone could offer any insight, that would be great.
Autozoner n civic owner is offline
Old 11-30-2005, 09:02 PM   #2
93vicb16a2's Avatar
i did it on a 93 coupe the parking brake cables are different.
i used the rear lines off the teg rear sus. i used
i changed the hole trailing arm cause i had them
if you need any more help let me know
Nick Bredemeyer
93vicb16a2 is offline
Old 11-30-2005, 09:05 PM   #3
Originally Posted by 93vicb16a2 @ Nov 30 2005, 09:02 PM) [post=593978
Quoted post[/post]]
Nick Bredemeyer
I know the trailing arms are the same, but are the hydraulic lines the same?
Old 11-30-2005, 09:51 PM   #4
Calesta's Avatar
Please refer to our FAQ. There is no need to post your topic more than once.
This topic has been closed by a moderator. Please continue your question in the other thread that you started.
Thanks, Moderating Team
[img]style_emoticons/<#EMO_DIR#>/locked2.gif[/img]
Calesta is offline
Closed Thread
© 2001-2013 HondaSwap.com
