This is a discussion on Rebuild Kit in the General Tech and Maintenance forum
Just wanting to know what everyone else thinks about this rebuild kit I found on ebay.. B16B Civic Type R Pistons Engine Kit Integra GSR B18C - eBay (item 120644965199 end time Nov-18-10 12:27:53 PST)...
| | #1 |
| Just wanting to know what everyone else thinks about this rebuild kit I found on ebay..B16B Civic Type R Pistons Engine Kit Integra GSR B18C - eBay (item 120644965199 end time Nov-18-10 12:27:53 PST) |
| | #2 |
| Looks like it's all there. Price isn't bad if those are OEM pistons. Doesn't look like it though. Bearings make me not want to trust it. OEM bearings or go home. I wouldn't buy it because of the bearings. OE bearings and I'd think about it. |
| | #3 |
| yeah i like OE bearings too. I just ran across it and thought it would be good to rebuild my friends motor. He liked the kit especially the price. I was just wondering if the parts are good.. |
| | #4 |
| good, fast, cheap. Pick two. |
| | #5 |
| good thought |
| | #6 |
| | #7 |
| then you didn't pick fast. you picked almost fast. |
| | #8 |
| fast for the price |
| | #9 |
| it's actually "reliable", not good...as good can be synonymous with all three combined(how "good" a setup is). You really don't have to pick, just balance all three(compromise). If you're patient and get lucky, you can definitely have all three(deals on quality parts). Last edited by K2e2vin; 12-26-2010 at 05:01 AM. |
| | #10 |
| Who here has experience with OEM bearings and ACL's? Who here has had bad experiences with either/or? No one? I ran ACL standards in my B20... they were plastigauged and uhm checked out within spec and have lasted! so... why all the OEM nutswinging? |
| | #11 |
| I've ran both YCP pistons and King bearings before, with zero problems. Really good products, in my opinion. |
| | #12 |
| Bearings should not be a concern so long as they're have the proper clearance. |
| | #13 |
| I'm using king bearings in my b16 with 20k trouble free miles. I rev it to 9k atleast once per drive, and she runs 4.5k down the interstate. oh yeah, mobile 1 synthetic oil... |
| | #14 |
| I am liking all the good opinions here.. now what about this kit with LS crank and LS rods. should be a good setup then.. with a GSR block B16 head... |
| | #15 |
| Are the bearings specifically for a GSR? If they are you might wanna double check to make sure the GSR bearings will work on w/an LS crank. I remember reading that the GSR mains are wider than an LS. Not entirely sure though. |
| | #16 |
| Ah your right brian I do believe they are. I think I saw that same thing in another thread... |
| | #17 |
| Because there's no fucking way the seller of that eBay kit could be selling the rebuild kit for the exact engine. Most people don't use the right size bearings on everything. |
| | #18 |
| OEM only works if you measure or use the table anyways. Not exactly fool-proof either. |
| | #19 |
| The LS crank and rods are just a thought right now.. but the kit we will probably get, for some reason money doesn't grow on trees in Ohio very well. |
| | #20 | |
| Quote:
which is why you'd plastiguage and check clearances while assembling... | |
| | #21 | |
| Quote:
| | #22 |
| Unless I'm misreading the description, the kit comes with main bearings, rod bearings and thrust washers... and typically plastiguage is something the engine builder/assembler has on hand. Shit, I havent built an engine in over a year and I have some laying around. bottom line, if its in your budget and you have half a clue on assembling your engine, go for it. this kit is 99% complete (that 1% being plastiguage and oil/assembly lube) |
| | #23 |
| so the parts then are a good name brand |
| | #24 |
| they are good stuff, I used the nippon pistons in my build and nippon master gasket set. ACL, King, and OEM bearings are all good. clearances is what makes things go wrong. If your building a OEM rebuild that will last 200k miles then yes go oem but if your building a budget build, ACL is a nice way to go IF they fit. you can always mix and match. |
Similar Threads | ||||
| B16 Rebuild | kpjuni | Engine Building | 14 | 02-23-2009 10:46 PM |
| ls rebuild | bigmackz01 | Engine Building | 15 | 04-23-2008 11:58 PM |
| help with ek rebuild | zsanchez | Civic and del Sol - EG and EK | 2 | 05-29-2007 09:19 PM |
| will d15 rebuild kit..........? | file-error | Engine Building | 2 | 02-14-2007 12:24 PM |
| ZC rebuild | cheese9988 | Engine Building | 20 | 05-27-2004 03:14 AM |
