#26 |
d16a6/d16y8 "mini-me"
Ride: 1990 Honda Civic Si
Hey, thanks for the GREAT write-up. I was never going to take my transmission apart until I read this step-by-step and I am a visual learner so this REALLY helped out. Thanks again. I am going to rebuild my 1990' Civic Cx (D15b2) transmission (by rebuild I mean clean and check the 4th gear). I just have a question; I was taking the casing off and it will not come off, is this because I have not removed the intermediate shaft?. One more question; I am rebuilding my D16a6 block and D16y8 head so will an LSD do anything for power on this set-up. I have CAI, header, some headwork and a couple of other little things for power. Would LSD be suitable for the enigne I mentioned above. Thanks and I am REALLY sorry to pester you with a lot of questions.
#27 | |
universal logic protocol
Ride: 99 VW GTI 07 Jeep Compass
Did you open this snap ring?
![]() As far as adding an LSD it helps with traction not power. In other words you build the engine to have the power and the LSD helps you put that power to the ground. __________________
99 VW GTI <= BIG F'IN POS <= Finally got it fixed, it's running good now 07 Jeep Compass If you ever find anything I write usefull please leave rep. Rebuilding a Transmission http://www.the-whiterabbit.com |
#28 |
No I did not pull the snap ring out, but I will as soon as I get the snap ring pliers. Are they sold as "Snap Ring Pliers"?. As well, thank you for the information on the LSD, I will take it into account considering I only have 140-145 hp; I highly doubt it would be a good buy for my engine combo. Thanks again!.
| Rebuilding transmission | whiterabbit06 | General Tech and Maintenance | 4 | 04-11-2008 11:33 AM |
| z6 mild rebuilding | bistec | Engine Building | 7 | 03-22-2007 11:04 AM |
| Rebuilding LS | brian11to1 | Engine Building | 2 | 08-30-2004 02:02 PM |
| Need help on rebuilding | tphan4 | Engine Building | 11 | 07-02-2004 01:59 AM |
| Rebuilding Turbo's | smashed4thgen | Forced Induction | 0 | 02-26-2003 07:56 AM |
