adrenaline is my high
Ride: 93 GSR Civic, 94 Civic (DD) 92 JDM RX7
Hey I know this has been mentioned a few times, but I need to know what all has to be removed. First, do I need to buy one of those kits? Second, if I remove all the hoses, pump, resevoir, etc, is my rack and pinion going to sease? Do I need to remove the control unit? Do I need to swap the steering set-up from a non-power steering civic? Any help would be great, oh and the vehicle is a 93 Civic with a B18C1. Thanks in advance, and pics would help too
Admin with a big stick
Ride: 2003 S2000
Loop your hoses into a vented catch can, make sure the steering rack is full of fluid, then remove everything else associated with the power steering system. The breather can will allow you to keep the faster ratio power rack without working against a locked up power steering system.
Ride: 2003 S2000
Yup
#6 |
Ride: 2003 S2000
The breather is important to make sure that you don't build up pressure in the system. Just the catch can on its own will help a LOT, and you can always drill the top and add a vented filter to it later if you want. The 2 main goals you want to achieve are to keep pressure in the system as low as possible, but not allow the system to get clogged up with air bubbles or run dry. You want to plumb your catch can such that you're always keeping fluid in the steering lines. Running the lines into the bottom of the can or at least to a point where there's always fluid going to them (no air) will do that.
| Adding power steering to a CRX | projectxspeed | HYBRID -> ED-EF / DA | 25 | 08-18-2009 02:26 AM |
| How to wire the horn for a Non-SRS steering wheel | civicious | General Tech and Maintenance | 0 | 05-12-2005 07:32 PM |
| Power Steering issue | AmonDin | HYBRID -> BA-BB /CA-CD | 5 | 05-01-2004 08:15 PM |
| power steering | oldschoolcivic | HYBRID -> ED-EF / DA | 2 | 04-18-2004 06:24 AM |
| By-passing the power steering | EK_spoon2 | HYBRID -> EG-EK / DC | 4 | 11-05-2003 05:58 AM |
