replacing oil pump on lsvtec
Old 07-28-2006, 10:30 PM   #1
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Rep Power: 217 Taco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
Default replacing oil pump on lsvtec
alright. first off i dont know what oil pump i have. when i rebuilt the motor i had no more money for an oil pump so i put the one that it came with back. This motor was already built once by someone else. I did however change the water pump to a gsr one. so i had to use the gsr belt.
Questions:
How can i tell what oil pump i have without tearing up the motor again. gsr timing belt cant be used with ls oil pump can it?
A link or info on how to change oil pump since i just got a type R pump(just to have a piece of mind)
i just dont want to be using a ls oil pump with my lsvtec. thanks guys
Its fashion man. The chicks you see walking down the runway dont wear practical clothes, they were something that was designed to make a statement. THat statement in turns influences and shapes other peoples designs and ideas.
Same thing with cars. Except with no attractive women... and a lot more gayness.
Taco15 is offline   Reply With Quote
Old 07-29-2006, 11:13 AM   #2
I dont think you can tell from the outside... depending on what year it is you could tell i guess. the pre-96's didnt have the spots for hte crank angle sensor thingy... good luck dude.
90 Integra Sedan
B20V 225 / 153
Old 07-29-2006, 11:37 AM   #3
Taco15's Avatar
Ride:  chevy s-10
myspace
yeah no shit. It looks like i'm gonna have to install the oil pump myself. I cant afford to pay anybody right now. I just need some tips and what to look for since i'm doing this with the motor still in the car
Old 07-30-2006, 07:01 AM   #4
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
you're doing the oil pump while the block is still in the car? Fun. Here's a little step-by-step.
1. Pull Header b pipe to gain oil pan access.
2. Pull oil pan. remember to drain oil, lol.
3. Remove valve cover.
4. Romove crank pulley.
5. Remove timing belt covers.
6. Loosen the timing belt. Slip timing belt off the crank and move out of the way.
7. Slip the timing belt sprocket off of the crank. This may be a pain, use plenty of penetrant lube. PB Blaster works well. WD40 is most likely adequate. Oh yeah, don't lose the crank pulley key.
8. Remove oil pickup.
9. Remove oil pump.
Installation is pretty much the reverse, with the timing needing to be set somewhere in the midst of putting it back together. Make sure to clean the mating surfaces really well; I use isopropyl alcohol to clean the surfaces before putting things back together-you don't want any oil residue on any of the mating surfaces, not even the oils off your skin. Use Hondabond sealant - silicon grey works for somethings, but is not nearly as good. That's pretty much it.
Edit: Oh yeah, the oilpump doesn't involve the timing belt at all, so no worries about the timing belt not fitting after swapping to the ITR pump.
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
Old 07-30-2006, 09:07 PM   #5
Taco15's Avatar
Ride:  chevy s-10
myspace
finally!!!!!!!!!!!! you come through again Mike. as soon as i get tim i'll get on it. i'm gonna have Andrew help me out. No i need to see if i can borrow my buddies shop so i can use his lift and tools. again thanks alot mike
Old 07-31-2006, 04:02 AM   #6
Blah blah blah....
MikeBergy's Avatar
no problem abel, tell us how it goes. it shouldn't take more than 3 or 4 hours of work if you have everything you need from the start and are organized. The sprocket on the crank can sometimes be a little rusty or corroded, so once you pull the timing belt, hit the sprocket with some penetrant lube and just let it sit. I didn't do that, and it was a pain in the butt for me.
How to build a "reliable" lsvtec/b20vtec bambam General Tech Articles 2 07-02-2006 05:48 AM
lsvtec ls timing belt lsvtecguy Engine Building 2 02-08-2004 12:08 PM
Replacing Fuel Pump sol2nr Engine Building 1 06-01-2003 10:49 PM
oil pump endlesszeal Engine Building 1 12-31-2002 05:49 PM
