Can anyone tell me what are other symptoms of a rod knock other than the noise?
I am having some major problems with my car. I've been told that it is a rod knock but no one has pulled the engine apart yet, so its all speculation. I have a d16y8 in there right now. If it is a rod knock would anyone recommend having the engine machined and rebult for high performance because I already have a lot of money invested in it, intake, ignition system, pulleys, full exhaust and more? Or would you recommend swapping the motor and going up to a b16, b18 , or H22? i am more concerned with what is going to be better for my money if it would be cheaper to rebuild and throw a turbo on the d16 or get a better engine and go from there. Any info will help. |
you most likely spun a bering if you step on the gas it dosent pull hard but it gose and if you are looking to rebuild the you might need to resleve the motor and a new crank and mabe new valves depending on how bad you spun the bering and how much you drive the car like that.
#3 | |
In all honesty, I would pull the motor and throw in a dirty cheap B16. Then tear it apart and see whats up with it, maybe fix it and sell it or keep it for a spare motor.
Friends Don't Let Friends Apex Early |
#4 | |
with a rod knock, theres usually cylinder wall damage, crank damage, and journal damage (where the crank spins), if it gets real outta hand, line boring aint cheap. The longer you drive it, the longer the list gets of bad parts, and eventually the engine will let go.
93 'Yota Truck 06 Harley 1200 Sporty Custom 94 EG2 (waiting in pops hands) "What was is was, and what is is is. And what is, is whats happening right now." Paul Sr. |
| Knock Sensor Question | hondaflr | General Tech and Maintenance | 6 | 07-12-2004 01:55 AM |
| How to wire a knock sensor? | tdaddylove | HYBRID -> ED-EF / DA | 5 | 03-23-2004 06:47 PM |
| Help with Knock Sensor on B16a2 Engine | tdaddylove | HYBRID -> ED-EF / DA | 3 | 03-18-2004 02:21 PM |
| h-22 knock sensor | h-22 accord | ECU's, Electronics, and Tuning | 6 | 11-16-2003 03:35 AM |
| h-22 knock sensor | h-22 accord | ECU's, Electronics, and Tuning | 1 | 11-11-2003 09:48 AM |
