Rough Driving
Old 01-17-2003, 07:24 PM   #1
Rep Power: 43 vtecsir1 will become famous soon enough
i swapped in a vx motor in place of my cx, the only sensors not hooked up are the vtec solenoid and the oil pressure. the car runs real rough and wont rev past 4k rpm, what could this be vtec and oil? i checked plugs and wires. it is also running very rich, i am running the vx ecu.
vtecsir1 is offline   Reply With Quote
Old 01-17-2003, 07:54 PM   #2
Rep Power: 19 Liquidblaze is off the scale
Send a message via AIM to Liquidblaze
Why don't you just plug up the oil pressure and vtec solenoid and get it over with?
Visit my site: <a href=\'http://www.hsvteamadrenaline.com\' target=\'_blank\'>www.hsvteamadrena line.com</a>
Please take a moment and sign the guestbook. Thanks!
Liquidblaze is offline   Reply With Quote
Old 01-17-2003, 08:21 PM   #3
well if i had them on my harness i would, i have a stock cx harness
Old 01-18-2003, 04:06 AM   #4
Rep Power: 17 chevy302dz is off the scale
Is the ECU throwing any codes? If not then double check the wiring, if you're running rich and getting spark it's either to much fuel or not enough air assuming it's sensor related. If that all checks out then try timing and checking for a vac. leak.
</span><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (Pissedoffsol @ Posted: Apr 15 2003, 12:35 AM)</td></tr><tr><td id=\'QUOTE\'>killing a saturn is like beating off and calling it sex</td></tr></table><span class=\'signature\'>
chevy302dz is offline   Reply With Quote
knife edged crank for daily driving word Engine Building 10 06-11-2004 09:12 PM
Atlanta study links time spent driving... 94RedSiGal Members' Lounge 10 06-01-2004 02:47 PM
Rough Idle Problem? loneranger General Tech and Maintenance 13 06-07-2003 01:58 AM
Driving Styles pissedoffsol Members' Lounge 19 05-28-2003 04:25 PM
30 Things To Do While Driving pissedoffsol Members' Lounge 14 05-24-2003 04:29 PM
