RSX trim question
Old 02-08-2004, 11:54 PM   #1
Rep Power: 18 H22AdelSol is off the scale
Is the rsx-s k20 that is made in the u.s. have a 6speed tranny? or do some have 5speed and other 6speed. I was thinking all type s models are 6speed. am wrong?
<span style=\'color:red\'><span style=\'font-family:Geneva\'>94 JDM H22A|5spd-LSD|GSR Spec Brembo Cross Drilled and Slotted Rotors| GSR Front Calipers| SS Lines|Tokico Illumina Struts| Skunk2 Coilovers| AEM Fuel Rail| ACT Stage 3 Clutch /w Xtreme Pressure Plate| 8lb Kaiten Kairu Super Flywheel</span></span>
H22AdelSol is offline   Reply With Quote
Old 02-08-2004, 11:57 PM   #2
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
k20a2 engines are the 200 hp RSX Type S models, they come ONLY with a 6 speed.
k20a3 engines are the 160 hp RSX Base models, they come with either a 4 sp auto or a 5 sp manual.
K20a engines are in the 02+ Civic Si and also have 160 hp, they come with a 5 sp manual
They're only built in the US/Canada. In Japan, the RSX (with the same body) is actually the Integra Type R.
XBL: jams 8201 (14,580G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is offline   Reply With Quote
Old 02-09-2004, 12:02 AM   #3
ok cool, just makin sure the wrecked car i buy is the 6 speed version.
Old 02-09-2004, 01:34 AM   #4
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
the civic and the base rsx a3 are the same motor
Old 03-07-2004, 11:01 AM   #5
Rep Power: 23 cycloneb18c3 is off the scale
Send a message via AIM to cycloneb18c3
actually on my brothers 02 civic si it says it was built in england.
whoever said nothing is impossible, never tried slamming a revolving door
cycloneb18c3 is offline   Reply With Quote
Old 03-07-2004, 07:17 PM   #6
There isnt a base model Integra in Japan?
90 Integra Sedan
B20V 225 / 153
Old 03-07-2004, 08:26 PM   #7
Rep Power: 12 jwn7 is off the scale
just to confirm, as the first post was a little unclear (si has a3):
the jdm integra type r actually has the k20a engine w/ 6spd of course 220ps
the rsx-s has the k20a2 with 6spd 200hp
the base rsx and civic si have the k20a3 with 5spd. 160hp = gay
i'm pretty sure there is a base model integra in japan, and instead of the type-s, they have the type-r, which is basically the same as our type-s, but with slightly higher compression. similar to the usdm and jdm gs-r & type-r of the old days. this is just what somebody on a local forum was blabbing, so don't kill me if it's wrong.
i'm really starting to think i'm wasting my time with a B18... have you guys seen any of the early K20 builds yet?
jwn7 is offline   Reply With Quote
Old 03-08-2004, 12:37 AM   #8
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
No.
The RSX-S is not just a ITR with slightly less compression.
It IS similar to the LS VS GSR vs ITR comparison. The LS would be the base RSX, the GSR would be the type S, and the ITR would be well the ITR. For the type R versions of the cars, they have much stiffer chassis, stronger/beefer suspension peices, bigger brakes, ect.
The RSX-S engine actually comes in the CTR over in Japan and Europe.
In japan, they have both the Integra iS and the Integra type R however, no type S (because the type S is basicly a CTR)
Collin
Material Science and Engineering
Michigan Technological University
Old 03-08-2004, 02:58 PM   #9
thanks for correcting me.
what engine is in the iS? is it the k20a3?
Old 03-08-2004, 03:14 PM   #10
basicly, it has 160PS from what the honda.co.jp site said and a 5spd.
Like previous engines like the b-series, in japan, the ITR engine has the same code as the iS engine. Just like the b18c is both an ITR and a SIR-G there. Both are k20a's but it is comprable to the k20a3
Collin
90' HB DX w/d15, auto \ going to d16 ECU QUESTION lcompeau ECU's, Electronics, and Tuning 2 05-28-2004 10:25 AM
Turbo on a b18b in a 95 teg projectxspeed Forced Induction 10 02-13-2004 03:13 PM
QUestion on LS swap Hatchback 95 hybrid HYBRID -> EG-EK / DC 3 08-23-2003 03:24 AM
Question 22crazy Forced Induction 1 01-26-2003 01:01 AM
Basic turbo question zueke Forced Induction 6 10-28-2002 07:04 AM
