Safe rev for a d15b2
Old 09-23-2003, 04:09 PM   #1
rudeludenotmeanthough is off the scale
A friend of mine has a 90 Civic hatch DX with a d15b2. His car is not equiped with a tach, so we are going to install one. No not a monster tach, just a lil one that get the job done. sorry to disappoint you guys... :P But anyways, i would like to know where the red line starts on these motors. Thank you.
rudeludenotmeanthough is offline   Reply With Quote
Old 09-23-2003, 04:28 PM   #2
EGLSHB is off the scale
Send a message via AIM to EGLSHB
hmm... if i remember correctly ,. the redline on the D15 motors starts shortly after idle...... but realistcally... i wouldn't take it past 5500... maybe 6000.....
EGLSHB is offline   Reply With Quote
Old 09-23-2003, 04:36 PM   #3
that seems kinda low. But obviously i have no clue or else i wouldnt have posted the question. Any other input?
Old 09-23-2003, 04:47 PM   #4
well... we are talking about an older motor... i am sure it will rev higher than that... and i am not sure where the fuel cutoff is, probably 65-6700 RPM,
but the numbers i gave are strictly for "playing it safe"
Old 09-23-2003, 04:59 PM   #5
hcivic.com is on a distinguished road
ya i blew my b2 at 8200 rpm and the second one worked up to 7200 with the limiter removed and fuel bumped up. I still have the b2 as a back up in the corner and it ran strong for 7 mounths until i removed it
hcivic.com is offline   Reply With Quote
Old 09-23-2003, 06:05 PM   #6
so what would you recommend as a safe redline on this motor?
Old 09-23-2003, 06:20 PM   #7
commador is off the scale
6500 should be a good redline. My d15 will pull until around there, then it runs out of cam, ha, I need to do a mini-me
commador is offline   Reply With Quote
Would it be safe to I revv up to 8.5 RPM Teambypass HYBRID -> EG-EK / DC 31 07-30-2006 11:17 PM
Safe boost level and what times to expect? RyanA Engine Building 0 04-24-2004 07:44 AM
d15b2 engine part replacement BLKWDW HYBRID -> ED-EF / DA 4 02-25-2004 08:36 PM
d15b2 motor, tranny, ecu, axles...etc b18c5rx Parts: For Sale/Trade/Wanted 3 12-22-2003 03:09 PM
help... think car is in safe mode... asiangel General Tech and Maintenance 0 11-03-2003 11:54 PM
