This is a discussion on Settin The Timing Belt in the General Tech and Maintenance forum
I was just wondering when i did my timing belt i matched all the lines up but then i released the timing belt tensioner on my h22 and rotated it counter clock wise.. than i rechecked them and it was than off! Do i have ...
| | #1 |
| I was just wondering when i did my timing belt i matched all the lines up but then i released the timing belt tensioner on my h22 and rotated it counter clock wise.. than i rechecked them and it was than off! Do i have to maybe restart and maybe move the cam gear a bit so than the two cams gears dont match up when i dont have tension on the belt and after i release them they than match up to one another! Sorry if this doesnt make the best sense but bear with me |
| | #2 |
| put everything to TDC.. keep the tensioner loose.. then slide that bitch on and tighten the tensioner. if it's still off then maybe you have the wrong belt?? |
| | #3 |
| also, make sure the belt has no slack at all where it faces towards the front of the car, the slack should be on the side towards the rear of the car, then tighten the tensioner pulley. |
| | #4 |
| Why does the #1 cylinder have to be at top dead center when you put on the new belt? And how do you tighten the timming belt correctly? |
| | #5 | |
| Quote:
| | #6 |
| Its sounds so easy... but on the h22 the timing belt tensioner is way diffrent! To loosen it you must take it all the way off... put it in a vice take the top off it use a small screw driver and turn it so it compresses than put it in a little jig that comes with a new one! POS |
| | #7 |
| Well i guess you dont have to worry about getting the thing to be the right tension because its on an autotensioner system! Thats a plus i guess! But i have one more question! When i turned the motor counter clock wise about ten times the timing belt came off the cam gears about a 1/16 of an inch! is that normal and will go away when i start running the car? Thanks |
| | #8 |
Similar Threads | ||||
| Timing Belt Repleacement | closedhood97 | General Tech and Maintenance | 9 | 02-09-2007 11:43 PM |
| ZC timing belt??? | twotwo | General Tech and Maintenance | 8 | 04-25-2004 10:14 PM |
| how to time | minivan | HYBRID -> ED-EF / DA | 2 | 02-03-2004 01:33 PM |
| B16 Timing Belt on LS?? | AllMotorSi | General Tech and Maintenance | 6 | 01-27-2004 11:03 PM |
| For Sale: 1991 Eagle Talon TSi | chet | Vehicles: For Sale/Trade/Wanted | 4 | 01-05-2004 08:56 AM |
