shift interlock problem
Old 07-07-2009, 02:28 PM   #1
Greenhorn
Rep Power: 0 el902276 is on a distinguished road
Default shift interlock problem
I have a 2005 Accord EX 4cyl and am having a problem with the shift interlock system. The shifter is stuck in park, I must use the shift release to shift out of park.
I have already checked the brake switch and it is good.
I checked the shift release solenoid at the gear shift and it is good.
I thought the problem might be the throttle position sensor. I tested the output voltage of the tps and it is 0.5 volts closed and ~4.5 volts at WOT which I believe is the correct reading.
Now the strange thing is that if I unplug the throttle position sensor, the shift lock release works fine. As soon as I plug the tps in again, the shifter doesn't release again. Can anyone help? Thanks!
el902276 is offline   Reply With Quote
Old 07-12-2009, 12:11 PM   #2
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 184 awptickes has a reputation beyond repute
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
If memory serves, there is a switch and a lock in the key cylinder too, check that and make sure it works properly.
☻/ DIY/Howto HID Projector retrofit
awptickes is offline   Reply With Quote
Honda S2000 2000-2004 Clutch: Clutch pedal, clutch interlock and more master23 s2000 0 06-28-2009 08:41 PM
shift linkage problem NXTCeg HYBRID -> EG-EK / DC 2 03-19-2008 12:33 PM
tail lights/shift interlock system peeonu25 General Tech and Maintenance 1 05-20-2007 03:48 PM
H22A Clutch Problem. Won't shift while running, will when off. New Clutch & Flywhee mjolson29 Prelude 1 04-09-2007 12:27 PM
FS: GSR Hydro Tranny Parts > Shift Forks , Reverse Change Holder , Shift Mechanism .. D See 2 Parts: For Sale/Trade/Wanted 1 11-29-2006 11:08 PM
