Shooting blue and/or orange fire out of exhaust
Old 11-01-2005, 09:37 PM   #1
DwnShftPrincess's Avatar
Rep Power: 14 DwnShftPrincess will become famous soon enough
Send a message via Yahoo to DwnShftPrincess
Listen
I gotta a stock D16Y8 w/ intake setup, stage 1 clutch, lightweight flywheel, ngk iridium plugs, and some cheap pipe with no cat.
My car has been spitting fire since earlier this year w/only a pipe, intake, and even w/a cat. Orange fire comes with a loud pop blue fire comes with a deep tone "woooooof"
It happens between accelerating or deccelerating and shifting into higher or lower gears, no matter the rpm or speed. Curious as to why? Will I blow up? How do I make it permanent? I want to make it happen on my 98 mustang.
[img]style_emoticons/<#EMO_DIR#>/driver.gif[/img]
127 hp = 2 rabbitts and a squirrel
DwnShftPrincess is offline   Reply With Quote
Old 11-01-2005, 09:59 PM   #2
Rep Power: 22 randerson165 is off the scale
lookup "fast and furious" on google!
<a href=\'http://www.securitymonster.com\' target=\'_blank\'>Security Monster</a>
randerson165 is offline   Reply With Quote
Old 11-01-2005, 10:07 PM   #3
tip
Rep Power: 13 tip is an unknown quantity at this point
<div class='quotetop'>QUOTE(DwnShftPrinc ess @ Nov 1 2005, 08:37 PM) Quoted post</div><div class='quotemain'>
Listen
[/b][/quote]
caused by the complete absence of back pressure.
tip is offline   Reply With Quote
Old 11-01-2005, 10:20 PM   #4
Rep Power: 59 hcivic.com is on a distinguished road
is called a backfire and its bad
hcivic.com is offline   Reply With Quote
Old 11-01-2005, 10:34 PM   #5
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
youre too fast for your exhaust...
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 11-01-2005, 11:05 PM   #6
Rep Power: 15 Xaero3953 is off the scale
Send a message via AIM to Xaero3953 Send a message via Yahoo to Xaero3953
<div class='quotetop'>QUOTE(randerson165 @ Nov 1 2005, 08:59 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[img]style_emoticons/<#EMO_DIR#>/268.gif[/img] [img]style_emoticons/<#EMO_DIR#>/268.gif[/img] [img]style_emoticons/<#EMO_DIR#>/268.gif[/img]
If God is your co-pilot, change seats.
Don't for one second be ashamed of these scars on your chest, you're just wearing on the outside what the rest of us wear on the inside.
Xaero3953 is offline   Reply With Quote
Old 11-01-2005, 11:57 PM   #7
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
<div class='quotetop'>QUOTE(tip @ Nov 1 2005, 09:07 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I doubt it- probably a cylinder not firing and fuel getting thrown straight out the exhaust, then ignited by the exhaust temps and thrown out the rear end as flames.
Something is probably wrong with your ignition, or you're running REALLY rich for some reason. When you lift off the throttle, you're dumping excess fuel through the engine and into the exhaust system where it's igniting and throwing flames.
Old 11-02-2005, 12:20 AM   #8
Rep Power: 19 kaoskustoms is off the scale
Send a message via Yahoo to kaoskustoms
deff a problem sounds like fast and furious spark plug in the tail pipe to me
honda the replacment for displacment
ummmmm vtec
kaoskustoms is offline   Reply With Quote
Old 11-02-2005, 12:36 AM   #9
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
definitely back firing (fuel that ignites when it hits the exhaust manifold)...couldnt tell you whats causing it...might be spark plugs too cold for your engine. might be bad ignition coil. might be bad wires. might be bad compression on cylinder. ya never really know until you look at it.
Anime Informant
reikoshea is offline   Reply With Quote
Old 11-02-2005, 02:00 AM   #10
Rep Power: 13 lude9593 is off the scale
Send a message via AIM to lude9593
<div class='quotetop'>QUOTE(DwnShftPrinc ess @ Nov 1 2005, 09:37 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
why in the world would you want your car to constantly backfire and shoot flames? when i (and i think this goes for most people who have a brain) see a car backfire all the time, i think to myself, "well goddamn, look at that pile of shit". just some food for thought.
'95 Prelude SE
AEM Intake, DC Sports Header &amp; Cat-back, Exedy Stage 1 clutch, Fidanza lightweight flywheel.
9.734 @ 72.913 MPH (1/8th)
lude9593 is offline   Reply With Quote
Old 11-02-2005, 02:03 AM   #11
Dustin_m's Avatar
Ride:  2001 Jeep Cherokee
Rep Power: 83 Dustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud of
myspace  FaceBook
<div class='quotetop'>QUOTE(lude9593 @ Nov 2 2005, 02:00 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[/b][/quote]
i dunno, i saw a nice Turbo RX7 today that shot some nice lookin flames when shifting. its the Gen. before the FD, iworked on this guys car before. it has the japanese motor swap, and he got the car, did the swap, and didn't even know how to drive stick. he was 16 or 17 and it was his first car. nice ass car though, and fast.
Originally Posted by E_SolSi View Post
frankly ill be surprised if you ever form a post that doesn't read like you are wearing a hockey helmet chewing on a box of crayons drooling all over yourself while you lick the fucking monitor and mash away at the keyboard
My Photostream on Flickr
Dustin_m is offline   Reply With Quote
Old 11-02-2005, 09:11 AM   #12
HS Troll...And Mod
reikoshea's Avatar
myspace
Lol, thats a rotary thing. when you run high boost on those things....it just happends spontaneously...not much you can do about it. usually on those it only happends while up shifting.
Anime Informant
Old 11-02-2005, 09:27 AM   #13
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 411 reckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
beware of this flaming exhaust...
if you are dumping THAT much fuel there's a good chance you could wash down the cylinder walls, ashing down = excess gas removes the oil film from the cylinder wall, thus no lubrication ='ing fucked up motor...
I'll blow a hole in your face then go inside and sleep like a baby.
reckedracing is offline   Reply With Quote
Old 11-02-2005, 05:10 PM   #14
[/b][/quote]
FYI: i've seen M5's and other european cars that shoot blue fire out the back and the last thing in my mind is look at that piece of shit. food for thought, i didn't know why it's happening that's why i'm asking. [img]style_emoticons/<#EMO_DIR#>/moon5.gif[/img]
Thanks to all of those that have posted USEFUL information and solutions instead of worthless opinions.
With that said, this started when i had the motor replaced in january. i swapped out a d16y8 with 279874 miles on it for a d16y8 with 39861 miles on it. could this be a bad motor? where do i start as to looking for the problem? Thanks in Advance
Old 11-02-2005, 05:15 PM   #15
TTIWWOP
start by pulling plug wires one at a time with the motor running, if it bogs after removal then that cylinder is firing...
if all cylinders are firing you might want to check your FPR?
do you have a check engine light?
<div class='quotetop'>QUOTE</div><div class='quotemain'>FYI: i've seen M5's and other european cars that shoot blue fire out the back and the last thing in my mind is look at that piece of shit. food for thought, i didn't know why it's happening that's why i'm asking. [/b][/quote]
bahahaha
there's a huge diffrence between a highly modded M5 shooting flames and lets say my 1981 4 door tercel...
that was a jumping king before i ripped the rear shock towers apart [img]style_emoticons/<#EMO_DIR#>/sad.gif[/img]
Old 11-02-2005, 05:20 PM   #16
Check engine light is on but has been since last year when the first motor was in. It has never turned off. BTW: I didn't remove the cat until february because it became ridiculously clogged and wasn't allowing me to drive.
Old 11-02-2005, 05:45 PM   #17
HS Troll...And Mod
reikoshea's Avatar
myspace
might wanna check the code. the service connector is usually behind the passenger floor board side pannel. if it has never been checked before, it will be a neon green housing thing (not connected to anything)
pull out the 2 wire plug and jump the holes with a paper clip. When you turn your ignition on (but dont start the engine) your check engine light should blink. Tell us what it blinks
Long blinks = 10
Short Blinks = 1
If there are multiple codes it will wait a few seconds and then blink again
e.g. 2 long blinks and 3 short ones = code 23 (knock sensor) 4 long blinks and 1 short one = 41 (02 Sensor)
Let us know what you get...
Anime Informant
Old 11-15-2005, 03:21 PM   #18
<div class='quotetop'>QUOTE(reikoshea @ Nov 2 2005, 05:45 PM) Quoted post</div><div class='quotemain'>
Long blinks = 10
Short Blinks = 1
[/b][/quote]
i found the green connector but it is connected to another green connector so do i unplug it? Thanks
also, what is the silver connector on the driver side by the hood release for?
Old 11-15-2005, 04:44 PM   #19
TTIWWOP
the green connector should be plugged into a larger green boot like thing... not actually plugged into any other wires...
Old 11-16-2005, 12:13 PM   #20
the green connector is connected to another green connector with wires on each ends.
Old 11-16-2005, 12:14 PM   #21
TTIWWOP
bad link, or link ot image
can;t see it
this connector has no other wires going to/from it
its a green connector that goes in a green boot with another plug NEXT to it in the boot, but not plugged into it...
and it has the brown wire...
hard to miss
image works now, and no thats not it
this is a green connector with only 2 wires, ONLY 2
Old 11-16-2005, 12:21 PM   #22
headed back outside
do i need to move anything out of the way to find it?
Old 11-16-2005, 12:45 PM   #23
i found it. however there is only one plug in the neon green boot and the plug is blue but it does have 2 wires that run to it. i had to move the ecu and i couldn't find the other plug missing from the boot.
i jumped the blue plug anyway and got 1 fast blink.
Old 11-16-2005, 12:45 PM   #24
TTIWWOP
uh, kick panel, carpet? etc?
what year is your car?
Old 11-16-2005, 12:48 PM   #25
<div class='quotetop'>QUOTE(reckedracing @ Nov 16 2005, 12:45 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
96. i even took the glove box down. i plugged the connector again and only got i fast blink.
