SiR II Tranny Problems
Old 05-06-2004, 08:42 PM   #1
Rep Power: 0 Osbee330 is off the scale
i have a friend who is selling a jdm sir II tranny. the only problem is that the 5th gear synchro is messed up. he wants $300 for the tranny. how much would it cost and how hard would it be to put a new synchro in? is it worth it?
Osbee330 is offline   Reply With Quote
Old 05-06-2004, 09:50 PM   #2
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
I sure as hell wouldn't buy it. I have no idea how much it would cost to fix, but most people go buy a new tranny when they kill a syncro.
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 05-06-2004, 11:23 PM   #3
usually the costs out weigh the initial investment into the tranny, but ask around and see what prices you get for the fix. Could potentially be worth it,
I know the SiR2 tranny runs around 600-900.
I got mine for 300, with 16k "s4", not a scratch on her and ran great...
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 05-07-2004, 10:03 AM   #4
adnoh's Avatar
Rep Power: 23 adnoh is on a distinguished road
heh....this sounds all too farmiliar. When I bought my B16A2, the tranny had the same problem. But mine was from second to third instead of fourth to fifth. Since I am in Toronto, Canada, my pricing may seem a bit odd but here it goes....... Since the synchro's on B-series trannies come in packs of two (1+2, 3+4, 5), for me it was more expensive. Now I dont know for sure, but I think that 5th is a synchro on it's own (correct me if I'm wrong). It took my mechanic a total of 6 hours to do this job. 2H to pull the tranny, 2H to install the new synchro's, then 2H to put the tranny back on, top up fluids and everything else. The whole ordeal cost me $650CDN. inc. labour. I dont know if the 5th sync. is any cheaper than the rest, but it might be. Now I had the option of just replacing my tranny completely, and buying a used JDM B16 Tranny, which is probably what I would have done if I had more $. But everything works great now, and Im totally happy with the rebuild.
My advice: If you can afford a new tranny with a not broken synchro, then do it instead, but if you want this one, then that's fine too. It will most likely end up costing the same in the end.
1998 Acura Integra Type R #864
adnoh is offline   Reply With Quote
Tranny problems. Spooner HYBRID -> ED-EF / DA 3 04-21-2004 11:38 PM
tranny grinds gears (synchro problems) kingmarc63 General Tech and Maintenance 24 01-05-2004 06:36 AM
Tranny Problems? Raxx General Tech and Maintenance 2 05-14-2003 07:23 AM
Tranny Problems seerx HYBRID -> EG-EK / DC 0 04-22-2003 10:16 AM
Zc Tranny Problems. hardweapon HYBRID -> EG-EK / DC 1 03-24-2003 11:07 AM
