Smokin?
Old 11-24-2007, 11:35 PM   #1
Ride:  93 delslow si
Rep Power: 5 ghsbaseball91 is on a distinguished road
Default Smokin?
In my 93 del sol si..a lot of smoke(burnin oil im guessin from the blackness above my exhaust) is comin from the exhaust..what could this mean?..thanks
ghsbaseball91 is offline   Reply With Quote
Old 11-25-2007, 12:20 AM   #2
AHHVTEC's Avatar
what color is the smoke
Old 11-25-2007, 10:31 AM   #3
Ride:  93 delslow si
the smoke is white
Old 11-25-2007, 10:39 AM   #4
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
myspace
white = coolant
black = rich fuel mixture
Old 11-25-2007, 10:44 AM   #5
AHHVTEC's Avatar
yea what he said ^^ and blue =oil burning
Old 11-25-2007, 10:50 AM   #6
Ride:  93 delslow si
so does that explain the black right above my exhaust on my bumper? and does that mean im leakin coolant or what?
Old 11-25-2007, 10:52 AM   #7
YBLEGAL's Avatar
myspace
it's possible your running rich AND burning coolant. the next thing i would do is a compression test.
Old 11-25-2007, 10:54 AM   #8
AHHVTEC's Avatar
if the smoke is real white and stays that way, there is coolant getting in the motor somewhere
Old 11-25-2007, 08:43 PM   #9
Honda Master Technician
norcalgsr's Avatar
Ride:  88 Prelude Si and a CBR 600 Hurricane
Rep Power: 21 norcalgsr is a jewel in the roughnorcalgsr is a jewel in the roughnorcalgsr is a jewel in the rough
myspace
Time for a compression and leak down test.
Do not PM with tech questions without providing a link to your topic on the forums. This way everyone has access to the information..
norcalgsr is offline   Reply With Quote
Old 11-25-2007, 11:33 PM   #10
Ride:  93 delslow si
i have no idea what u mean by runnin rich, and what is a compression and leak down test?
Old 11-26-2007, 12:24 AM   #11
norcalgsr's Avatar
myspace
They are tests to determine the condition of your engine. I would recommend you take your car to a shop and have those tests done as there is definitely a problem with your engine, and with your limited knowledge doing the tests yourself would probably not be a good idea.
Usually when you have white smoke coming from the exhaust it is caused by a blown head gasket, warped head, or a cracked head or block. The only way to know for sure is to have those tests performed on your engine.
Old 11-26-2007, 01:31 AM   #12
YBLEGAL's Avatar
myspace
and running rich means that your car is putting too much fuel into the engine.
Old 11-28-2007, 10:53 AM   #13
Ride:  93 delslow si
how much do those tests usually cost?
Old 11-28-2007, 02:42 PM   #14
YBLEGAL's Avatar
myspace
they're not too difficult. i would expect $10-30 depending on the mechanic. Most local mechs do a diagnosis for 20 bucks around here.
Old 11-28-2007, 04:21 PM   #15
Ride:  93 delslow si
thats not bad..i was expectin a lot, what all will those tests be able to tell from my engine, not just where the smokes from?
Old 11-28-2007, 05:51 PM   #16
norcalgsr's Avatar
myspace
They will basically tell you if anything inside your engine (piston rings, valve seats, head, block) is damaged and where it is damaged. It will most likely explain the cause of the smoke, and determine what you need to do to repair it.
Old 12-02-2007, 08:12 PM   #17
Banned
Ride:  Obviously a space ship?
Rep Power: 0 ReDCiViCSi can only hope to improve
Hey this has been very helpful to me guys, thanks much. Sadly i'm burning oil....it's blueish smoke but only when i first start my car an when i take off from a stop....what could that be??
ReDCiViCSi is offline   Reply With Quote
Old 12-02-2007, 08:35 PM   #18
norcalgsr's Avatar
myspace
Probably leaking valve stem seals, worn piston rings, or a combination of both.
Old 12-02-2007, 08:54 PM   #19
Banned
thanks much. I'll have one of the mechanics figure out if he can fix that tomorrow or sometime this week. =]
Old 12-02-2007, 08:56 PM   #20
norcalgsr's Avatar
myspace
It won't be a cheap fix if that's the problem.. start with a compression & leak down test and see what the results are.
Old 12-02-2007, 09:00 PM   #21
Banned
alright, what is your opinion on just taking off the head an doing a minime swap? an getting that stuff looked over an replaced at the same time? or should i just work on getting a new engine... i work at an autobody shop so i can get the labor done cheaper...an do some myself.. what would you do?
Old 12-02-2007, 09:13 PM   #22
norcalgsr's Avatar
myspace
If your block is still in good shape the mini-me would be a good idea. I would probably pull the engine and have the block inspected to see what kind of condition everything is in. If the cylinders and crank are still within spec you can replace the rod/main bearings and piston rings and have a near new block. On the other hand if you need to bore the cylinders or replace the crank it might be a better idea to start searching for a new engine since the D series are pretty cheap in comparison to a full rebuild.
I would start a new thread if you have anymore questions too.. so you're not taking over the original poster's question.
Old 12-02-2007, 09:20 PM   #23
Banned
i think from what you an ahhhvtec have told me, i'm going to buy a sohc vtec engine tomorrow an use that for a few months an then in the summer i'm gonna drop the gsr in there. thanks for all you're help though. =]
Old 12-03-2007, 12:11 PM   #24
Filer0128's Avatar
Ride:  92' Civic CX Hatchback
Rep Power: 0 Filer0128 has a little shameless behaviour in the past
Send a message via AIM to Filer0128
92 Dx Smokes??? This thread is about the same thing and has alot of useful stuff on what engine to get for your situationwdc
Filer0128 is offline   Reply With Quote
Old 12-03-2007, 12:26 PM   #25
Banned
that's for telling me....i posted it.
but then i found this in the archives an somehow everybody is posting on both.
but thanks for letting me know anyways because i may have not seen it
Smokin H lazyAE86 General Tech and Maintenance 1 02-26-2006 12:48 PM
