Speedo Cable
Old 02-16-2003, 09:31 PM   #1
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
ok guys i just had my speedometer cable replace on account of it being broken and my mechanic told me that i would have problems with it and that there was a possibility that it would break again. he told me that the stock CRX cable was not long enough and he was forced to make a tight turn in the cable. luckily the cable lasted long enough to pass inspection but it broke again. now it costs me about 200 bucks everytime that it needs to be replaced, and i cant afford to keep replacing it. now what i want to know is if speedo cables are interchangable, since the CRX one isnt long enough, i was wondering if one from another honda may be longer, like from an integra or sumthing. see i know that the connector to the tranny are all the same, but i want to know if the connector to the speedometer is the same. and if anyone knows which cable is long enough or any other info will be greatly appreciated. also my mechanic said something to me about a universal cable that you cut to the right length, would this be a good alternative too? this option will be a last resort if i cant get a real cable. any and all help is appreciated. thanks.
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 02-17-2003, 12:04 PM   #2
GSRCRXsi's Avatar
cmon everyone i need an answer on this one. thanks.
91 CRX si
95 Integra LS
Old 02-17-2003, 12:17 PM   #3
Rep Power: 25 SixtySecondAssassin is off the scale
maybe one from a 2nd gen teg will work.
.....deagle.....
SixtySecondAssassin is offline   Reply With Quote
Old 02-17-2003, 06:52 PM   #4
GSRCRXsi's Avatar
why? does it have the same connectors as the CRX? is it longer?
91 CRX si
95 Integra LS
Speedo Cable, B18A in CRX Question CReX123 General Tech and Maintenance 2 07-07-2004 02:03 PM
Speedo Cable FamilyD General Tech and Maintenance 1 03-14-2004 09:53 PM
Where does speedo cable go? fardoche HYBRID -> ED-EF / DA 2 07-05-2003 10:53 AM
Which Speedo Cable? inspecta83 General Tech and Maintenance 4 04-02-2003 07:13 AM
Speedo Cable GSRCRXsi General Tech and Maintenance 1 01-07-2003 06:05 PM
