Which Speedo Cable?
Old 03-30-2003, 12:29 AM   #1
Rep Power: 16 inspecta83 is off the scale
im wrapping up my b18b1 swap into a crx. i tried to hook up the speedometer cable today, but it seems to be too short. i am using the crx speedometer cable and was wondering....is the speedometer cable from the integra longer, and would it reach? or are they all the same size and i am just not hooking it up correctly?
thanks
"sunshine plays a major part in the daytime.....peace to mankind ghostface carry your black 9..."
inspecta83 is offline   Reply With Quote
Old 03-30-2003, 03:27 PM   #2
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
i had this same problem with my b18c swap in my crx. the cable kept snapping. if you go to advanced auto parts, buy a speedo cable for the 1991 CRX si. that cable should fit your car and is plenty long enough. also another problem i had with it was it kept snapping. this was because where it hooks into the tranny, the engine bracket is right overtop of it and it was bent too much, you cant do that with speedo cables. anywhoo, what i did was drill a hole in the bracket so the cable would fit through and go straight down to where it hooks in. hope i helped, and whatever you do, dont make sharp turns in the cable, you want as wide turns as possible, or else it wont last long.
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 03-31-2003, 09:12 PM   #3
thanks for the input....the speedo cable that i was trying to make work was from a 1991 crx si... ....so, does this mean im screwed?
Old 04-02-2003, 12:39 AM   #4
GSRCRXsi's Avatar
no you shouldnt be, but if it doesnt fit, go buy one from advance auto. maybe the one they get is a bit longer than the OEM counterpart. all i know is i got two cables from there and when i put it in i had plenty of cable to spare, at least a few inches.
91 CRX si
95 Integra LS
Old 04-02-2003, 07:13 AM   #5
Slo86GT's Avatar
Rep Power: 48 Slo86GT is an unknown quantity at this point
Send a message via AIM to Slo86GT Send a message via MSN to Slo86GT Send a message via Yahoo to Slo86GT
make sure it's going DIRECTLY to the tranny. Not swinging around any hoses, or wire looms or anything. Directly from the firewall to the tranny, only.
I'm still using my Stock 91 Si cable on my B16a swap.
- Jody -
2004 Colorado ZQ8 - I5, M5, Regular cab - 209.9whp/210.7wtq
1986 Mustang GT - V8, M5 - 213.0whp/279.2wtq
Slo86GT is offline   Reply With Quote
Speedo Cable, B18A in CRX Question CReX123 General Tech and Maintenance 2 07-07-2004 02:03 PM
Speedo Cable FamilyD General Tech and Maintenance 1 03-14-2004 09:53 PM
Where does speedo cable go? fardoche HYBRID -> ED-EF / DA 2 07-05-2003 10:53 AM
Speedo Cable GSRCRXsi General Tech and Maintenance 3 02-17-2003 06:52 PM
Speedo Cable GSRCRXsi General Tech and Maintenance 1 01-07-2003 06:05 PM
