ok guys i need a quick reply on this, so hopefully someon will be able to help. ok im replacing the speedometer cable on my CRX. i took off the cluster and follow the cable down under the dash, and nearly to the floor. but i loose it there, i cant find where it goes or even where it hooks on the transmission. i dont know if it makes a difference, but the tranny is a YS1 and mated with a B18C1 engine. now i need to know how to do this, or if someone can give me step by step instructions, that would be great, but like i said, im trying to do this right now so i need the answer super quick if at all possible. many thanks and
for anyone that helps!!! |
GNU/Linux Evangelist
Ride: The Cheapest Road Bicycle I could get
You probably lost it where it went through the firewall. In the engine bay standing on the passenger side of the car, start at where the starter motor attaches to the transmission. Now look a little to the left. The speedo cable should be right there under part of the wiring harness. If you still have the head on the engine it will be a tight fit to get you hand in there.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com |
| Speedo Cable, B18A in CRX Question | CReX123 | General Tech and Maintenance | 2 | 07-07-2004 02:03 PM |
| Speedo Cable | FamilyD | General Tech and Maintenance | 1 | 03-14-2004 09:53 PM |
| Which Speedo Cable? | inspecta83 | General Tech and Maintenance | 4 | 04-02-2003 07:13 AM |
| Speedo Cable | GSRCRXsi | General Tech and Maintenance | 3 | 02-17-2003 06:52 PM |
| Speedo Cable | GSRCRXsi | General Tech and Maintenance | 1 | 01-07-2003 06:05 PM |
