Temp. Guage going up/down erratically
Old 09-22-2003, 03:10 PM   #1
Rep Power: 18 RFHOMI2U is off the scale
Ok, I have this little problem in my CRX. It's an 88 CRX Si (stock Si Motor), yet i am having a problem with the stock temp guage. The car will be fine until after about 10 minutes of driving. Then the temp guage will go all the way up to hot. And then very quickly it will drop all the way down to the normal temp. (just below half way). Then it will go just below the red mark and stay there. This all happens when I all of a sudden get the faint smell of coolant. It's weird. It is full with coolant and water and has a brand new thermostat. (OEM replacement, opens at 185). Under the hood after driving, the upper radiator hose seems to be pressurized a little more than normal, and there is a little bit of coolant sitting on the radiator fan as well as the radiator. i can't hear any leaks, and cannot find any leaks. Any suggestions? any ideas what may be wrong? What should I try next to fix this problem?
Boosted LS CRX --- Loving the fact that it never runs.
After 10G's of work without drivability - seriously considering setting it on fire.
RFHOMI2U is offline   Reply With Quote
Old 09-22-2003, 10:09 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Replace the hose... but that's not your problem. Most likely it's your temperature sensor on the side of the block. My CRX did the same thing as yours (temp gauge), so I replaced the sensors and it was cured.
Old 09-23-2003, 08:01 PM   #3
tab
Ride:  03 Avalanche
Rep Power: 51 tab is on a distinguished road
Send a message via MSN to tab
yeah, probably a bad temp sender. You have at least one switch, a sensor, and a sender. The sender does nothing but send a signal to your dash. Its the little guy on the side of your head, probably just below your distributor. Might be a bad connection. I'd just get one from a junkyard.
2003 Chevy Avalanche
Leather, Moonroof, Z71, tow package, bose+six disc, nice.
1992 Accord EX (sold to good friends)
JDM H22A
H22A Auto Tranny w/LSD
I/H/E -- All stainless w/2.5 inch Catback
1968 Oldsmobile Toronado
Project car, 455 ci front wheel drive, nasty.
Gas Guage help YouKnowWhoIBee ECU's, Electronics, and Tuning 0 03-28-2004 10:44 PM
Gauge cluster+ indiglo guages= big problem YouKnowWhoIBee ECU's, Electronics, and Tuning 6 02-27-2004 01:55 AM
Low Temp Thermostat sol2nr Engine Building 19 08-29-2003 01:41 PM
Coolant temp sensor issues LS/VTecEF9 General Tech and Maintenance 2 07-30-2003 07:08 AM
Water Temp Guage 93dxKID General Tech and Maintenance 0 05-22-2003 11:40 PM
