throttle bodies
Old 07-05-2004, 09:17 PM   #1
Rep Power: 16 wisemansoji is off the scale
I put in 1.6L sohc vtec in a 93 sedan, can I use the 1.5L throttle body that was on the stock engine, cuz the 1.6 didn't come with a throttle body.
Or are the throttle bodies different , does the 1.6L need a bigger one.
wisemansoji is offline   Reply With Quote
Old 07-05-2004, 09:53 PM   #2
Rep Power: 35 NotUrAverage_Si is off the scale
You should be able to use the throttle body from the 1.5L on the 1.6L's manifold. The bore size of the 1.6L TB may be a little bigger than the 1.5's, I'm not all that familiar with single cams, but they should be interchangeable.
'00 <span style=\"color:black\">FBP</span> Civic <span style=\"color:red\">Si</span>-T
|<a href=\"http://www.full-race.com\" target=\"_blank\">full-race</a>|<a href=\"http://www.goldeneaglemfg.com\" target=\"_blank\">golden eagle</a>|<a href=\"http://www.fast-turbo.com\" target=\"_blank\">fast-turbo</a>|<a href=\"http://www.hondata.com\" target=\"_blank\">hondata</a>|<a href=\"http://www.wiredspeed.com\" target=\"_blank\">wiredspeedlab</a>|
email: boostfedEM1@yahoo.com
<div class=\'quotetop\'>QUOTE(dohch22a4 @ Sep 20 2004, 11:44 AM)</div><div class=\'quotemain\'> Please, Obi Wan B, you're our only hope.
</div>
<span style=\"font-size:36pt;line-height:100%\"> <a href=\"http://www.nissantech.com\" target=\"_blank\">www.NissanTech.co m</a></span>
NotUrAverage_Si is offline   Reply With Quote
Old 07-06-2004, 12:32 AM   #3
Rep Power: 15 B18aCRX is off the scale
Send a message via AIM to B18aCRX
^^^Agreed
Double Check Sizes Here
<span style=\"font-size:8pt;line-height:100%\">
<a href=\"http://www.hondaswap.com/forums/index.php?showtopic=35492\" target=\"_blank\">Hondaswap Vouch</a></span>
<a href=\"http://www.norcalcrx.org/forum/\" target=\"_blank\">Nor Cal CRX Club</a>
<span style=\"font-size:8pt;line-height:100%\">Bar Approved 1988 CRX LS</span>
<span style=\"font-size:8pt;line-height:100%\">1996 Accord LX</span>
B18aCRX is offline   Reply With Quote
