Throttle Body Cooling Lines
Old 07-03-2003, 02:43 AM   #1
Rep Power: 24 Accordturbo94 is off the scale
Hey Whats up I was just wondering what would happen if you were to take off the coolant lines that run through the throttle body on an h22?? What exactly do they do! They come off the thermostat houseing and one runs to the throttle body and than one out of the throotle body goes to some other piece on the manifold and than back to another spot on the thermostat housing! Any Ideas
Accordturbo94 is offline   Reply With Quote
Old 07-03-2003, 03:11 AM   #2
Rep Power: 0 jason is off the scale
i would leave them alone. the solinoid on the manifold is the idle control solinoid. and the one on the bottom of the throttlebody is the startup high idle valve. they both work together for your car to idle proper. if you bypass them, your sensors will think that your car is cold and will run a rich mixture all the time.
jason is offline   Reply With Quote
Edelbrock 65mm throttle body Teambypass Engine Building 5 07-06-2004 07:24 AM
65MM Edelbrock Throttle Body....... tlb1127 Engine Building 1 05-21-2004 12:00 PM
throttle body question StealthMode HYBRID -> EG-EK / DC 0 02-02-2004 07:48 PM
Fs: Itr Throttle Body pills_PMD Parts: For Sale/Trade/Wanted 4 02-26-2003 12:24 AM
Throttle Body Cooling RFHOMI2U General Tech and Maintenance 4 02-12-2003 12:57 AM
