Throwout bearing problem
Old 01-02-2008, 02:58 AM   #1
Beast
Kanned's Avatar
Ride:  Stuff
Rep Power: 72 Kanned has a reputation beyond repute
Kanned has a reputation beyond reputeKanned has a reputation beyond reputeKanned has a reputation beyond reputeKanned has a reputation beyond reputeKanned has a reputation beyond reputeKanned has a reputation beyond repute
Default Throwout bearing problem
Ok, so my throwout bearing has been going for like 2 months now. With the clutch engaged, you can hear the deep rattling that stops when you disengage it. It doesn't ever grind, but the car just seems to go into gear kinda rough after it's warmed up. I have a couple questions...
What will happen when the throwout bearing kicks the bucket?
A new clutch was installed with this bearing 8k miles ago and it's already bad... What could cause it to go out so fast?
Thanks in advance,
Sean
Insert something clever here.
Originally Posted by boostedf22 View Post
Like I say, it just aint sex with out a little meat to beat
INJEN78: check your vtec juice
Spinal: my vtec juice..?
Kanned is offline   Reply With Quote
Old 01-02-2008, 03:01 AM   #2
AHHVTEC's Avatar
are you sure thats the problem,,8k it should still be good,maybe its the tranny going bad, have you checked the fluid for it
AHHVTEC is online now   Reply With Quote
Old 01-02-2008, 04:14 AM   #3
Beast
Kanned's Avatar
Ride:  Stuff
Motor was completely rebuilt and has since had 8k miles on it. The old tranny was already having problems, but I put in a new clutch and throwout bearing in when assembling the car. The old tranny went out on me while on the freeway(It jammed, car wouldn't move with clutch in). 4k miles ago is when I installed the current tranny that had 50k on it(legit). It has since had 10w40 synthetic motor oil in it filled to the top from the speed sensor hole and hasn't lost a drop of fluid to this day. It seems to distinctly be the throwout bearing judging by the sound and how it stops when the clutch is disengaged.
Old 01-02-2008, 04:23 AM   #4
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
Pull it apart....
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 01-02-2008, 04:24 AM   #5
The Trisexual
It's only only like 6 hours of work. I remember I fucked up the TOB and I finished it before dark.
Worse comes to worse, you have to do it all over and replace the tranny.
Current Rides
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
253whp
Old 01-02-2008, 04:44 AM   #6
Beast
Kanned's Avatar
Ride:  Stuff
This may sound cocky, but I can replace said bearing in under an hour with a lift. I'm just trying to figure out something I may not know before I take the tranny off. Something that may make it go out so fast that I can look for while I'm in there. The tranny itself is doing its' job fine, except the shifting getting slightly rougher at times(Which is probably nothing at all). I don't exactly have another few hundred bucks laying around for a tranny, don't jinx me please =(.
Old 01-02-2008, 04:49 AM   #7
The Trisexual
Not cocky at all, I'm talking about with a floor jack and stands. It's very possible to do it in an hour with a lift and some good air tools.
You might have gotten a faulty TOB. It;s happened to me before.
Current Rides
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
253whp
Old 01-02-2008, 11:20 AM   #8
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
make sure you lubed that shit up like woah. did you put the TOB clip on?
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 01-02-2008, 02:10 PM   #9
Beast
Kanned's Avatar
Ride:  Stuff
Ugh, may have found our problem right there.... I didn't cover it in grease. I'm also drawing a blank on the clip, I'll find out when I tear it apart. Thanks a lot.
Old 01-02-2008, 03:03 PM   #10
be happy you dont have to change your transmission out in a foot of snow next weekend.
Old 01-02-2008, 04:15 PM   #11
Beast
Kanned's Avatar
Ride:  Stuff
Werd, that would be ideal.
Wtf is snow? I have cows watching me while I work on my car.
Old 01-03-2008, 03:48 AM   #12
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Make sure your clutch is adjusted properly. the release bearing is not supposed to be engaged at all times, it is supposed to be completely free of the pressure plate when it is disengaged. Sometimes over-slipping a clutch will cause this premature failure or excessive contact with the pressure plate. When the clutch begins to wear down, the clearance between these parts change. Might as well replace the whole clutch setup and re-surface/balance the flywheel and install a new release bearing (throwout bearing).
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 01-03-2008, 03:51 AM   #13
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
The answer to your questions is simple; Its your driving. Just for reference, you do have to break in clutches. 500 miles is usually the norm.
Old 01-03-2008, 04:57 AM   #14
The Trisexual
Fuck it while you crack her open, throw a lighter flwheel in also. 11 pounder would be my choice.
Current Rides
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
253whp
Old 01-05-2008, 12:23 PM   #15
Beast
Kanned's Avatar
Ride:  Stuff
Yeah, I figured some odd driving methods could have had something to do with it. My exhaust gets WAY too loud at certain RPM's, so I find myself shifting too early a lot of the time. I'm not a bad driver, but it is possible. Maybe it just wasn't adjusted right in the first place =/. Great advice/point.
Thanks
Old 01-05-2008, 12:48 PM   #16
The G37....
get_nick's Avatar
Ride:  Black G37, '07 R6
Rep Power: 266 get_nick has a reputation beyond reputeget_nick has a reputation beyond repute
get_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond repute
 FaceBook
it will do that if you ride the clutch also. just try to keep an eye on how you are driving.
I changed the page layout. let me know what you think. I need feedback.
www.obamacies.com
get_nick is offline   Reply With Quote
Old 01-06-2008, 12:17 AM   #17
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Thanks
Shifting too early won't cause bearing failure, its actually easier on the bearings. There are many different causes of bearing failure/early failure. An unbalanced flywheel is one that is common today.
Your welcome.
Old 01-06-2008, 11:52 AM   #18
would having 4 outta 5 flywheel bolts holding the flywheel on cause the same type of failure?
Old 01-06-2008, 10:52 PM   #19
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Unless that one bolt that is missing causes an imbalance, I would have to say no.
Old 01-08-2008, 04:32 PM   #20
DwnShftPrincess's Avatar
Rep Power: 14 DwnShftPrincess will become famous soon enough
Send a message via Yahoo to DwnShftPrincess
are you sure it's not your tranny? synchros could be going bad. also after you fix it change over to pennzoil synchromesh for tranny fluid
127 hp = 2 rabbitts and a squirrel
DwnShftPrincess is offline   Reply With Quote
Old 01-09-2008, 11:19 AM   #21
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
What does a synchronizer have to do with a release bearing noise? Shhh.
Old 01-09-2008, 12:25 PM   #22
just giving a suggestion dude
Old 01-09-2008, 02:47 PM   #23
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
It's not nice to give suggestion's if you do not understand how things work. People get the wrong idea. But sorry for snapping at ya, miss.
Old 01-09-2008, 05:09 PM   #24
Beast
Kanned's Avatar
Ride:  Stuff
I appreciate all the suggestions, but I'm not a complete noob, so I'm not gonna rip my tranny apart cause of some possibility. I'm pretty positive what it is, but I was wondering what to look out for considering I'm not going to replace it for probably another two weeks. Otherwise, I would've just ripped the thing off, peaked around a bit, replace the TOB, and wish for the best.
Electronical problem with honda accord 95 jay_nightrider General Tech and Maintenance 2 12-04-2006 12:39 PM
Old Problem, Revisted YBLEGAL HYBRID -> EG-EK / DC 4 11-25-2006 08:45 PM
VTEC Solenoid problem... Intevic Productions HYBRID -> EG-EK / DC 5 08-17-2006 07:05 AM
Electrical Problem With My 1986 CRX Si The_MATRIX General Tech and Maintenance 0 06-17-2004 06:08 PM
clutch problem after swap welfare HYBRID -> EG-EK / DC 0 05-12-2004 11:51 PM
