ticking fun
Old 05-13-2008, 09:47 PM   #1
/\ IDIOT ALERT /\
MazdaAspec's Avatar
Ride:  91 Honda Cr-x HF
Rep Power: 7 MazdaAspec will become famous soon enoughMazdaAspec will become famous soon enough
myspace
Default ticking fun
I have read the few threads I found on this topic but none really help on e bit. The ticking is coming from the head but not sure if it will hurt un hard driving conditions. The sound goes away when going up hills but returns when I level out or go down hill. There are many things I read like timing, bent valve, and other things. Will it be bad if I race it like that. OOOO one more Q, when I turn the key the fuel pump will not kick in at times. If it does it generally means it will start and be fine. Others it willl start but die right away, then when I try to start it again, my pump wont kick in and it will just sit there and turn and not start. The reason I threw the Q in there is it related to the ticking proble.
Thanks for the help.
XBL gamer tag: MazdaAspec (Play Forza 2, left 4 dead, and COD4.) add me!!!
www.myspace.com/mazdaaspec Watch My 91 Cr-x autox. Quick little bugger.
-92 Toyota Corolla= FIXED daily driver and gave to the parents
-91 Honda Crx HF= AutoX car (Maybe, if it gets fixed)
-08 Subaru Legacy= New daily driver
MazdaAspec is offline   Reply With Quote
Old 05-13-2008, 09:51 PM   #2
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 215 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
The ticking sound. Check your valve lash, .3mm I believe, it says on your hood what it should be. The fuel pump problem. Either your main relay getting ready to take a dump or the fuel pump itself.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 05-13-2008, 09:55 PM   #3
/\ IDIOT ALERT /\
MazdaAspec's Avatar
myspace
I am not gonna lie in this situation, but like I put under my name that I am a ricer as of now. I dont know much about but am learning so please dont yell. Valve lash? and will it be the same even with a motor swap in it. I am working my ass of to get this car running correctly and had it for only a year. Forgive my retardness.
Old 05-13-2008, 10:05 PM   #4
My name is Byron.
efhondakid's Avatar
Its Ok everyone is new to something. Yes the adjustments are the same for just about every Honda motor. Valve lash is the the amount of free movement between the rocker and the valve. 6th Gen (6G) Honda Civic D-Series Valve Lash Clearance Adjustment This site will give you some pics and a better understaning. Pick up a service manual for motor you have, it will become your best friend, and a feeler gauge if you dont have one. Its not a hard process, any mechanicaly inclined person can do it.
^ (dont listen)
Old 05-13-2008, 10:07 PM   #5
/\ IDIOT ALERT /\
MazdaAspec's Avatar
myspace
HA HA HA sorry I am laughing but this phrase "Its not a hard process, any mechanicaly inclined person can do it." you like to use it dont you. I read your other posts and you had there as well on a brake question. I know the rocker and the valve part so I will look into from there Thanks
Old 05-13-2008, 10:08 PM   #6
My name is Byron.
efhondakid's Avatar
I do find myself using that qoute a lot. Glad I could help.
^ (dont listen)
Old 05-13-2008, 10:11 PM   #7
/\ IDIOT ALERT /\
MazdaAspec's Avatar
myspace
Awesome site there. I have a feeler gauge and will have to do that.
Motor Is Ticking Bad....... DelSlow89 Civic and del Sol - EG and EK 1 01-05-2007 10:53 AM
Engine ticking b20kid Engine Building 2 11-05-2006 06:24 PM
ticking in head 91integrab16a General Tech and Maintenance 2 10-21-2006 12:45 AM
ticking in 1st gen b16a 91integrab16a General Tech and Maintenance 8 09-30-2006 07:58 PM
Ticking solsteeler General Tech and Maintenance 2 05-10-2003 03:47 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
