timing belt
Old 08-30-2003, 09:57 PM   #1
Rep Power: 13 slammedcivic22 is off the scale
? has anyone ever done the timing belt and water pump on civic 96-98 ex civic them selfs??? wondering how difficult or easy it is.....is it a very labor intensive job???
slammedcivic22 is offline   Reply With Quote
Old 08-31-2003, 05:13 PM   #2
88 C1V1C 53D4N DR1V3R
saturn_boy96's Avatar
Ride:  2006 Suzuki Aerio
Rep Power: 31 saturn_boy96 will become famous soon enough
Send a message via AIM to saturn_boy96 Send a message via MSN to saturn_boy96 myspace
just make sure you have a really big breaker bar so you can get that crank pulley bolt off. everythign else is pretty easy, but make sure you read and reread the whole process be fore you start because once you start you have to finish it.
if you stop in the middle your car will not run, and if you do something wrong your car will break.
but really its not that hard just make sure you have ALL the right tools.
saturn_boy96 is offline   Reply With Quote
Old 08-31-2003, 05:58 PM   #3
I would say its about average, not too labor intensive but does require you to line up your timing correctly.
Get a helms or read some write up and go for it.
Milan
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 08-31-2003, 06:11 PM   #4
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
timing belt how too.
Collin
Material Science and Engineering
Michigan Technological University
Timing Belt Repleacement closedhood97 General Tech and Maintenance 9 02-10-2007 12:43 AM
ZC timing belt??? twotwo General Tech and Maintenance 8 04-25-2004 11:14 PM
lsvtec ls timing belt lsvtecguy Engine Building 2 02-08-2004 12:08 PM
how to time minivan HYBRID -> ED-EF / DA 2 02-03-2004 02:33 PM
B16 Timing Belt on LS?? AllMotorSi General Tech and Maintenance 6 01-28-2004 12:03 AM
