I swapped over a tranny today and ran into some problems. I car will shift into gear, but will not move. You have to keep the pedal depressed unless the engine dies off. 3rd 4th moves a little but makes a rattle noise. The clutch i got is from a junk yard and don't know if it'll work. The only mistake i know i did was that i took off my VTEC Solenoid and oil dripped just a tiny drop on it. HELP GUYS!
1991 Honda CRX Si, JDM B18C GSR Swap, AEBS Manifold, CTR Pistons, DPR ITR Stage 5 Head, Skunk2 stage 2 Cams, Skunk2 cam gears, AEM V2, ANR Header, Greddy E-Manage, ACT 6 puck clutch, AEM fuel rail, Eagle Rods, Type R tranny, Enjo axles, Runs 12.8 ALL MOTOR! |
did you put all the things on right? the clutch, throwout bearing?? if yeah maybe that tranny is messed up.
my <a href=\'http://www.hondaswap.com/gallery/browse.php?album_id=668\' target=\'_blank\'>civic</a> can burn stationwagons.....when they're parked |
this is the replacment tranny i bought for the one i got jipped on ebay. And this is the second time i got jipped. In neutral, it moves forward a bit. i can't push the car unless i depress the clutch. and when it moves a little on 4 and 3 gear, i can hear a loud clattering noise. i can also smell burning clutch. i don't know what the hell to do.
uhh... maybe its your clutch??
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
#5 |
I found out the itīs not the clutch, i barely got any oil on there. The tranny i think is the problem, the shaft the sticks into the clutch doesnīt move at all, itīs rock hard, arenīt you suppose to have some freeplay there? itīs not in gear too.
